Map Sensor 1-2-3 bar?
Old Feb 15, 2011 | 05:18 PM
Swerve7rpm2000's Avatar
Default Map Sensor 1-2-3 bar?
Guys i have a map sensor with absolutly no numbers on it, is there a way i can test it and see what bar sensor it is? thanks
Old Feb 15, 2011 | 06:03 PM
Atomic's Avatar
I have a gauge for that
Sure, plug it in and measure the voltage output. If its a 1bar it will be full voltage at atmospheric, and if its 2 bar it will be half(ish).
Old Feb 15, 2011 | 07:07 PM
Thanks atomic!
Old Feb 15, 2011 | 10:03 PM
hey atomic can you give me a way to test it? i have to wire the sensor in where my old plug was, i turn the power on and where to i put my leads and what should meter read? thanks man.... If i understand properly if its a one bar with power to it ill have 5.0 volts and if its 2 bar ill have 2.5 ish? what would 3 bar be if this is correct
Old Feb 16, 2011 | 09:34 PM
Atomic's Avatar
There are 3 wires on the map, 5v, ground, and signal. The 5v and ground should be easy to identify, and the signal wire is the other one, probably the one in the middle. You can just connect it to a 5v battery and measure the signal prong if you want to. With the sensor in open air, a 1bar will be around 5v, 2bar around 2.5v, and 3bar around 1.6v. I say around because there is a voltage offset and slope adjustment, but it should be close to those values. Put you positive lead on the signal wire, and negative on the ground wire.
Old Feb 16, 2011 | 10:20 PM
sweet thanks man!! ill let ya know results
Old Jan 26, 2012 | 05:05 PM
Beatdown Z's Avatar
Laid Back
Did Atomic's method of testing the map sensor work well?
Old Jan 26, 2012 | 06:17 PM
Atomic's Avatar
Yes...
Old Jan 27, 2012 | 07:07 AM
Beatdown Z's Avatar
Laid Back
Tried it on my 3 bar map sensor and got about .98V
Still have to ditch it for a 2 bar map though...
natejk
Nov 15, 2016 08:05 AM
Tydriver
45
Oct 23, 2015 09:19 PM
chvy=power
Oct 20, 2015 09:08 AM
chopperloco
Sep 28, 2015 08:40 AM
TAPyvehc93
Sep 17, 2015 10:10 AM
