Maf maxed out?!?
Old Jun 6, 2012 | 10:20 PM
Black BMF's Avatar
Default Maf maxed out?!?
I have a 5.3 with a ls6 cam and a turbo on 8psi. The maf is pretty much maxed at 8 psi but I want 10 psi! I want to stay maf so what are my options?
Old Jun 7, 2012 | 10:50 AM
slow67's Avatar
Gingervitis Addict
Maxed out in hz or fuel?
Old Jun 7, 2012 | 11:03 AM
nonnieselman's Avatar
go to 9psi, and then 10 psi if the afr and timing still look good.
Can pull a degree or two of timing from the far right side of your timing table before hand and add it back slowly.
Old Jun 7, 2012 | 10:11 PM
Area47's Avatar
put a larger intake/maf housing tube on it.
Old Jun 7, 2012 | 11:16 PM
Black BMF's Avatar
Maxed out in hz. I've had it to 10 psi but it wouldn't stay steady! I've been told the bigger pipe would help but I was wondering would a bigger maf like linginfelter help too?
Old Jun 8, 2012 | 02:11 PM
03sierraslt's Avatar
You could always go 2bar speed density.
Old Jun 8, 2012 | 02:24 PM
The maf is maxed out in Hz?
bigger maf wont do anything, its all the PCM will "read"
Old Jun 8, 2012 | 09:58 PM
Area47's Avatar
hmmm nope.
it will drop the resolution rate and read a lower hz.
Old Jun 9, 2012 | 08:38 AM
LsF-150's Avatar
Correct me if I'm wrong, is'nt the card style maf swap supposed to help with this problem?
Old Dec 13, 2012 | 09:30 AM
BIGHAL's Avatar
Mine is doing the same thing. Reading 12hz at 4200 at 8lbs of boost.
lucas287
31
Jan 12, 2021 06:18 AM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
2plus2
Sep 13, 2015 07:17 PM
JordanH
Sep 12, 2015 12:02 AM
