lpe gt1 cam installed now won't idle
Old Dec 20, 2005 | 07:19 PM
  #21
Flyer's Avatar
You need to match the base sprak tables close to the main tables. That will give you a smoother transition from one to the other.
About the fuel trims ... if you are getting -12 at idle, I would start with subtracting 10 from it in those cells, JUST the idle cells.
Old Dec 20, 2005 | 07:43 PM
  #22
02sierraz71_5.3's Avatar
Originally Posted by 4.8T
the pressure modifier for each shift is 0'ed out?.
thats the problem right there, the 1-2 should have some negative values at the lower calculated tq readings. If you dont have a shift kit and all the TM has been removed on a stock tranny this is a recipe for disaster the internal parts wont hold up.
the lower the number the less pressure the higher the number the more pressure, 0 is not a null value each tranny will be different
These are also the tables I use for modifying the 1-2 with a shift kit leave the base table stock and manipulate shift pressures with these tables. dont raise the force motor current table if anything it can go down. Aftermarket stall raise the tcc locking table. I think thats about all I use to adjust line pressure and shifting habits, dont have HPT in front of me.
ARC
57
Feb 21, 2022 10:54 AM
all_individual
Oct 10, 2015 10:09 PM
fillpot
Jul 26, 2015 07:21 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
all_individual
Jul 13, 2015 11:01 AM
