I need some help--- X Link not working at WOT
Old May 30, 2012 | 10:24 AM
jcroy454's Avatar
Default I need some help--- X Link not working at WOT
I have an 06 CCSB and I just did a 408 stroker swap into it. I went with L92 heads and intake. I also went with a 90mm TB from an 08 silverado. To adapt the wire harness I went with the x link. I am having a problem when I go WOT quickly it kicks it into reduce power mode. I reset the DTC (1516) and it works again. My tuner said that I needed to junk the x link and make my own harness. Has anyone else had this issue and if so how did u fix it? Thanks
Old May 30, 2012 | 10:43 AM
89LS1FOXER's Avatar
Everyone that i know using x-links are having similar issues? REP mode and getting 40% throttle when pedal is to the floor until we pull over and re-key it....
Old May 30, 2012 | 11:47 AM
TXSZ66AVLANCHE's Avatar
The x link in my truck has been fine....but another x link in a customer truck has problems.
Light throttle: ok
wot throttle: ok
Half throttle: NOT ok get reduced power mode.
So I open the x link and there is wires sealed in a brick of epoxy...to hide what's in there? I'm thinking its just wires making a loop and no actual adapters or electronics.
Old May 30, 2012 | 11:58 AM
89LS1FOXER's Avatar
Light throttle: ok
wot throttle: ok
Don't think that is the case but that would be funny!
Old May 30, 2012 | 12:23 PM
jcroy454's Avatar
I am looking at trying to make my own but I am not sure how the ECM will read the low ref wires. I am kind of at a loss if what to do at this point.
Old May 30, 2012 | 12:41 PM
Holty's Avatar
Notorious BIG
Isnt the guy who makes the Xlink a member of this forum? I would think he could chime in.
Old May 30, 2012 | 01:24 PM
jcroy454's Avatar
I wish he would. I have called him off and on all day with no answer.
Old May 30, 2012 | 01:43 PM
jcroy454's Avatar
I just talked to the guy at Torque Rush and he said that the TB blade is either hitting the stop or it has a burr or something causing it to bind up. He also told me it could be a bad engine ground. I am going to check these and see if it will work out.
Old May 30, 2012 | 01:51 PM
03tahoe22's Avatar
I had the same issue with my x-link when using the 08 Truck/TBSS throttle body design with a larger engine and blower. The spring in those throttle bodies arent strong enough for the larger amount of air demand and the blade moves further than then signal can read and puts it into rep or says the tps is broke. The solution for my was to use a ls2-7 throttle blade design and I have never had an issue.
Old May 30, 2012 | 03:06 PM
jcroy454's Avatar
Did you use the LS2-7 tb or just swap the blade and spring into your tbss tb?
