How to disable PE?
Old 03-13-2006, 01:41 PM
1slowsilverado's Avatar
You have hpt 2.0 + just leave PE on and filter it out. Its all in the help files.
Old 03-13-2006, 03:56 PM
02sierraz71_5.3's Avatar
BTW: I made those guides for use with the stock 02's and I never mentioned anything about disabling PE fueling
Old 03-13-2006, 04:07 PM
Hello Dave
dc_justin's Avatar
When tuning the VE do not enter PE mode this can be done by simply raising the edit-engine-fuel control-power enrich-tps enable-cold to 100 and avoiding going 100% throttle
That's effectively disabling it. 99% throttle fueling will be nearly identical to 100% throttle fueling and will not be in PE mode.
Old 03-13-2006, 04:30 PM
Hello Dave
dc_justin's Avatar
And don't get me wrong, I'm not knocking the guide. It was a great way to get started tuning.
And for the most part, if you use a safe timing table (eg low octane spark table with premium fuel), and up your VE 10% before you start, you should be fine to run near WOT with 14.7:1. Just be careful to watch for knock when you first start moving into higher load cells.
shawn96gmc
05-17-2016 04:15 PM
MA$TER_E
09-09-2015 03:14 PM
slowmo934
09-09-2015 12:24 PM
lxcoupe
08-31-2015 05:49 PM
Suburbazine
08-09-2015 01:17 AM
Quick Reply: How to disable PE?
