Help. Urgent!!!
Old Jun 11, 2016 | 01:22 PM
  #21
FFDP's Avatar
Doesn't seem like a battery/power issue at all. Because you did new battery and did jumper cables, it's going to have full juice.
Nothing with the KEY on at this point will pull enough to cause the battery to drain to nothing and stop the write. To me it's either the software or the computer is fried.
Old Jun 11, 2016 | 01:30 PM
  #22
About20ninj45's Avatar
My elm327 cheap ebay scanner can connect to it, but the hptuner scanner wont even read the ecu. it balks at me and tells me that it cant find my vehicles diagnostic protocol.. which is stupid. When i read my ecu the first time, i had to do it with the car on because i was having the same issues. My very first read with key on ignition of had the same symptoms and would just fail. So i started the car and read the ecu that way which worked. Im thinking its something with the software a this point. I have sent my log off to hpt and im awaiting thier support. In the mean time, i want to try everything else on my end before i go spend 150 dollars that i dont have on another pcm lol
If anyone can take a look at this, this is the file that im trying to flash..
File Type: hpt
Old Jun 11, 2016 | 01:32 PM
  #23
with the battery brand new in the truck, im only seeing 11 volts, with jumper cables, im seeing 14
Old Jun 11, 2016 | 01:55 PM
  #24
so< im going to go to the local u pull and see what they have. they told me that they have two chevy silverados there, one an 07 (they dont know if its classic or not) and one is an 04. Could i use either of those pcm's as a donor to segment swap my calibration on?
Old Jun 11, 2016 | 02:41 PM
  #25
1FastBrick's Avatar
Custm2500's Rude Friend
Depends what else's is on the communication bus.
Maybe another module or the lights
Old Jun 11, 2016 | 02:44 PM
  #26
1FastBrick's Avatar
What's it going in?
99-02 are specific and 03-07 classic are specific.
Old Jun 11, 2016 | 02:48 PM
  #27
1FastBrick's Avatar
That fact that another tool will communicate is an indication you have an issue with the HPTUNERS unit. Likely a software issue. Check that you have the latest calibration as well as the firmware being up to date.
Just re read and saw it was an 06 Denali
Old Jun 11, 2016 | 03:08 PM
  #28
ill try that first, but i thinkim still going to grab the pcm. they qouted me 15 bucks for both of them... so im gonna walk up there with my tools in my backpacks. Im going to try to grab the connectors as well so i can make a bench flash system, because if it isnt the software, then it has to be something with my vehicle.
the part number for my ecm , acccording to the dealership is 89017750....is that the same for multiple years?
Old Jun 11, 2016 | 03:10 PM
  #29
1FastBrick's Avatar
The number is different for each year because the software is different. The hardware is basically the same.
You can flash an 06 operating system in an 04 pcm.
Old Jun 11, 2016 | 03:20 PM
  #30
As long as my stick tune I saved was good. Because if not, I'm fqd. There are no time repositories for my truck. I will have the change the vin as well correct? Two credits?
