Help. Urgent!!!
Old Jun 10, 2016 | 04:56 PM
About20ninj45's Avatar
Default Help. Urgent!!!
I went to flash my ecu using up tuners and it keeps failing during the write procedure. My battery is only 6 mos old and my fuse is good. Someone please help me. Symptoms I have when writing is the gauges go all the way down then back to normal levels like the truck is shutting itself off. Any ideas? I'd hate to have to walk 20 miles to get home
Old Jun 10, 2016 | 06:00 PM
Wolftrk99's Avatar
Is the cable plugged in all the way... I hada similar situation with mine where it would just fail to write...
Old Jun 10, 2016 | 06:33 PM
03sierraslt's Avatar
What year and ecm?
Old Jun 10, 2016 | 06:35 PM
Yes cables all plugged in. 06 Yukon Denali and stock ecu
Old Jun 10, 2016 | 06:36 PM
Are you doing a Write or Write entire?
Old Jun 10, 2016 | 06:38 PM
While it tries to write the volt meter goes all the way to zero. Kinda like a key off during write.
Old Jun 10, 2016 | 06:44 PM
Battery terminals tight and good contact?
Old Jun 10, 2016 | 06:45 PM
Yes and I'm just doing a write Calibration
Old Jun 10, 2016 | 06:47 PM
Vehicle won't start now either because it erases the previous Calibration. Tried writing the stock file I saved and still no dice. It only write to 10 percent and then fails for timeout. Tried to use slow speed as well I stead of high speed and same result
Old Jun 10, 2016 | 09:11 PM
Flewbyu123's Avatar
Do you have a remote start in your truck?
