Help. Urgent!!!
Old Jun 10, 2016 | 10:51 PM
About20ninj45's Avatar
No.i don't believe so
Old Jun 10, 2016 | 10:58 PM
Are you using V2.24 or V3.0? In my experience once you fail a write on a P1 or P59 PCM and the software doesn't automatically go into recovery mode and continue the write, the PCM is bricked. Especially if you key cycled it.
Old Jun 10, 2016 | 11:03 PM
GMCtrk's Avatar
Sounds bricked, agree.
Time for a replacement pcm
Old Jun 11, 2016 | 02:53 AM
Key cycles after it failed. Git to 60 percent instead of 10 after I charged up the battery a little more. After calling around to some time shops, they say the p59 us kind of hard to brick. I'm using 3.0
Old Jun 11, 2016 | 03:13 AM
Described herehttp://http://www.hptuners.com/forum...ne-won-t-write
And also here
http://http://www.ls1gto.com/forums/...t=78466#/enter
Read post 10
Old Jun 11, 2016 | 12:39 PM
any other ideas?
Old Jun 11, 2016 | 12:51 PM
1FastBrick's Avatar
Custm2500's Rude Friend
This may be an indication your battery is no good.
Once the battery voltage drops below a certain voltage the flash process will stop to protect it self.
The OEM dealers have to use special charges that don't create electrical noise while flashing to insure this doesn't happen during the flash process.
Old Jun 11, 2016 | 12:53 PM
Wolftrk99's Avatar
You can also try fully charging the battery and either connecting a jump box or hooking another battery to it through a set of jumper cables!!!
Old Jun 11, 2016 | 01:04 PM
I think in HP tuners flash procedure it tells you not to do that. Went back up to AutoZone. Grab another new battery , 3rd today, and it's dong the same thing still.
Old Jun 11, 2016 | 01:18 PM
Trying the jumper cables now.... Same thing. Something is killing the f out of this battery when flashing. I pulled the radio amp and radio fuse just to make sure they aren't culprits. What am I missing?
