Dyno numbers and graphs
Old Apr 30, 2007 | 08:28 AM
TurboSlade's Avatar
Default Dyno numbers and graphs
So I finally went to the dyno after saying I was going to for the longest time, I never got base runs so I dont know how I compare but I believe I have alot more left at this boost level before I trun it up.
Tell me what you think
Old May 3, 2007 | 11:13 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Why are the scales in mph and not rpm?
The graphs look like a heart monitor for a guy having a heart attack. They should be a little more smooth. The number looks ok but, I think you can make much more.
How much boost?
Old May 3, 2007 | 11:47 PM
.T.'s Avatar
.T.
WTF? I think those drops are shift points at mph...?
Looks like @ 440tq and 370hp.
STS kit can build more power than that.
Are you AWD?
Old May 4, 2007 | 07:25 AM
TurboSlade's Avatar
I dont now why they are in MPH I will email him and see if he can send them over in RPM instead.
And yes thoise are shift pionts, the truck responded better by driving thru the gears on the dyno.
Not AWD RWD with 24's, they do rob me of power but they it is pimp to beat lightnings rollin 24's.
You can see I have alot of tuning left to do by my A/F ratios. And I am only pushion 5Lbs with the GT67. I think at 10Lbs and a great tune and a cam I can be at 500 to the wheels.
Should I change to TR6 plugs when I go to 10lbs?
We have the same kit on my dads Denali and with a base tune my brother decided to do a top speed test and destroyed the rings on #7 from the detonation. It was so bad it burnt the end of the spark plug off!! So I am alittle worried about high boost and these factory plugs.
Any suggestions would be helpful!
Old May 4, 2007 | 09:53 AM
ColtSteele's Avatar
what plugs are you running now? what tuning software are you using?
Old May 4, 2007 | 10:00 AM
TurboSlade's Avatar
I have the factory plugs gapped to 36, and I'm using a handheld Diablo...
Old May 4, 2007 | 10:22 AM
12secSS's Avatar
Guys, the Dyno Dynamics usually dyno 12%-14% lower then (internet compared) DynoJet numbers. Dyno Dynamics dyno similar to Mustang dynos. Those numbers would be about 412 or so. But yes, that graph is very sketchy.
Old May 4, 2007 | 11:23 AM
03sierraslt's Avatar
I would get those Iridiums out of there, they hold too much heat. Switch to some NGK TR-6 plugs, they come gapped at 35 and that is good.
Old May 4, 2007 | 04:40 PM
1SlowHoe's Avatar
Agreed.
You should be close to 500 with the right cam. The 24's do rob some power but they look good
At 9psi I am making 450/460
jscherbs
Mar 24, 2017 07:20 PM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
rednekferlife101
Sep 14, 2015 05:27 PM
norris_83
Sep 9, 2015 04:14 PM
11MPG
Sep 8, 2015 04:52 AM
