Does PCM must match harness? Blue/red
Old Aug 13, 2014 | 09:10 AM
dkiller2135's Avatar
Default Does PCM must match harness? Blue/red
Ive got a 1999 LQ4 harness and just noticed that the PCM that came with it is listed as a 1999-2000 Ls1. They both have the Blue/ red connectors.
Should I just buy another PCM for a 1999-2000 truck or Repin the harness for Ls1 or can I use the 2001-2004 411 PCM.
Thanks for the time.
Old Aug 13, 2014 | 11:05 AM
Should be the same service #. The calibration will be different. Shouldn't be a problem for any competent tuner.
Old Aug 13, 2014 | 05:08 PM
So you would buy one with right service number instead of reprinting the harness. Do you know if the 411 pcm is best. I believe its the sameppin out just faster.
Old Aug 13, 2014 | 08:39 PM
kbracing96's Avatar
411 is same pin out, just swap PCM's and get it tuned for mods . It's not so much the PCM that's at fault for the 99-00 trucks, it's more of the operating system. But a good tuner should be able to take care of you.
Old Aug 14, 2014 | 07:53 AM
sounds good. Looks like 100$ on Ebay will get a 411. There isn't any diffence in the return vs returnless fuel lines in the 411 are they. I can think of much difference in an 99 to 04.
Old Aug 14, 2014 | 09:09 AM
kbracing96's Avatar
The pcm makes no difference in fuel lines, but injector flow rate is setup different in the tune,
Old Aug 14, 2014 | 09:20 AM
GMCtrk's Avatar
No need to swap PCM.
Just change the calibration to the 2002 operating system.
Old Aug 15, 2014 | 08:43 AM
It does have a different service 1999-2000 Ls1 9354896
and the 1999-2000 Trucks have a 9"2"54896 and the pin out is different.
It doesnt look like a lot is changed on the pin out. Im just running the engine in a Jetboat so Im gonna try to repin the sensors to match. Then disable VATS and trans/other codes.
Old Aug 15, 2014 | 08:45 AM
If I change the calibration on a bench top harness, is that gonna alter the pinout inputs to PCM?
Old Aug 16, 2014 | 02:39 PM
IAT, MAP & TPS +/- pin locations are all that need repositioned to have a 1999-2000 truck harness match the 1999-2000 car PCM pin out. With only stand alone engine management running. No trans, egr,fuel pump. Just bare bones o2s, injectors, cam, crank, pcm power are all the same. 5 pins to move. Even the IAT + was the same location.
OHsixLS3
Nov 22, 2015 07:45 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
Wrecker 426
Sep 30, 2015 09:39 PM
Silver8ado
Sep 30, 2015 11:42 AM
StrokeTheLS
Sep 29, 2015 08:33 PM
