attn tuners 90mm tb idle issues
Old Aug 10, 2014 | 07:03 PM
Jason Z69's Avatar
Default attn tuners 90mm tb idle issues
I just installaed a ls2 gold blade 90mm. Ive been havin idle issues hard down shifts when slowing down and after driving if I rev the engine if it comes down its really slow from 3000 to 2000. My tuner isnt sure what the issue is. Any input would be great. Hptuners by the way.
Old Aug 11, 2014 | 10:50 AM
DrX's Avatar
DrX
Just on my phone this week, so no access to HPT, but check
that the throttle area is set correctly for the larger TB. Shouldn't
need any other changes in the tune for it to idle well. Should idle decent
even with no tune changes.
Old Aug 12, 2014 | 08:45 PM
TexasGMC08's Avatar
If i recall the LS3 90mm (gold butterfly blade) wont work due to it opening the reverse direction than the ls2 and ls1 style throttle bodies. But we can try changing the ETC Area Scalar from 5,060.2500 to 5,636.0000... Next time we meet up.
Old Aug 13, 2014 | 06:41 AM
Truckshop's Avatar
Need a idle relearn. If that don't fix it then the throttle body is bad.
Old Aug 16, 2014 | 03:27 PM
subeone's Avatar
You just need a tune.. Bring the raf down and increase throttle decay
Try lowering ignition timing a bit as well
Old Aug 17, 2014 | 08:37 PM
turboal1's Avatar
Default 90mm TB
change the TB size in the PCM
LCHEE
Oct 24, 2020 04:10 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
hackrst
Jul 11, 2015 11:17 AM
GreyChevy
Jul 7, 2015 08:57 PM
