Does PCM must match harness? Blue/red
Ive got a 1999 LQ4 harness and just noticed that the PCM that came with it is listed as a 1999-2000 Ls1. They both have the Blue/ red connectors.
Should I just buy another PCM for a 1999-2000 truck or Repin the harness for Ls1 or can I use the 2001-2004 411 PCM.
Thanks for the time.
411 is same pin out, just swap PCM's and get it tuned for mods
. It's not so much the PCM that's at fault for the 99-00 trucks, it's more of the operating system. But a good tuner should be able to take care of you.
It does have a different service 1999-2000 Ls1 9354896
and the 1999-2000 Trucks have a 9"2"54896 and the pin out is different.
It doesnt look like a lot is changed on the pin out. Im just running the engine in a Jetboat so Im gonna try to repin the sensors to match. Then disable VATS and trans/other codes.
IAT, MAP & TPS +/- pin locations are all that need repositioned to have a 1999-2000 truck harness match the 1999-2000 car PCM pin out. With only stand alone engine management running. No trans, egr,fuel pump. Just bare bones o2s, injectors, cam, crank, pcm power are all the same. 5 pins to move. Even the IAT + was the same location.
Wrecker 426
Sep 30, 2015 09:39 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
