Does a Leaner AFR = More Heat?
Old Nov 29, 2007 | 10:51 AM
BlackGMC's Avatar
Resident Retard
Default Does a Leaner AFR = More Heat?
I was wondering does a Leaner AFR create more heat? The reason I ask, is since it is almost winter would comanding a leaner mixture in the Lower ECT ranges (below normal operating temp) help speed up warm up times?
Old Nov 29, 2007 | 12:46 PM
Zick's Avatar
Yes a leaner mixture will create more heat. There have been many people that burned holes in their pistons due to a too lean condition. Usually thought that happens mostly under load.
If you plan on doing any kind of leaning out, I would highly recommend getting a Wide band.
EDIT: Opps, just read your sig again. Missed that you already have a WB.
Old Nov 29, 2007 | 12:57 PM
truckmann's Avatar
I am running mine at about 15.5 at light load conditions don't know that it really heats up much faster.
Old Nov 29, 2007 | 12:58 PM
03sierraslt's Avatar
+1 for the wideband if you are going to lean it out, hell +1 for the wideband period.
Old Nov 29, 2007 | 01:01 PM
Zick's Avatar
True, it makes it so easy to tune with one.
Nevermind, he already has a WB. Missed that.
Old Nov 29, 2007 | 01:05 PM
BlackGMC's Avatar
Resident Retard
Thanks guys, I do have a WB (see Sig). I was just mainly considering doing it at idle/in park. Every morning i warm up my truck for about 5-7min. It is my understanding that the computer is in Open-Loop if the (B4203) "Closed Loop Normal Temp" temp is not met. So my thinking would be to lean out he mixture in the lower ECT ranges on the "Commanded Fuel in Open Loop" table and raise the B4203 temperatue value up a little higher so the truck will warm up faster. Does that make sense?
Old Nov 29, 2007 | 04:12 PM
You actually want it to run a bit richer then stoich when it is warming up.
Old Dec 4, 2007 | 11:37 AM
zippy's Avatar
If you want it to warm up quicker when cold, raise the idle.
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
11
Oct 27, 2015 03:38 PM
turbo6c3
Oct 5, 2015 06:11 PM
old motorhead
Sep 29, 2015 08:22 PM
Shotguntommy
Sep 15, 2015 05:24 AM
