Does flashing the PCM reset the oil light?
Old Dec 16, 2005 | 11:29 PM
thunder550's Avatar
High on diesel fumes
Default Does flashing the PCM reset the oil light?
Just wondering if flashing the PCM resets the oil life calculator. I decided to stop changing oil every 3000 miles and do it when the light comes on, but I have flashed and reflashed several times since last reset.
Old Dec 16, 2005 | 11:39 PM
FILE's Avatar
I think that is controlled by the BCM.
Old Dec 17, 2005 | 12:07 AM
NoChrome's Avatar
3000mi!!! I change oil once a month no matter what. Its always pretty.
Old Dec 17, 2005 | 12:17 AM
1slowsilverado's Avatar
The Oil Change Life is mathmaticaly controlled by the PCM. It looks at engine tempetures, load, combustion and other parameters to determin oil life.
I would think if you were just flashing calibrations changes and not rewriting the entire PCM its would not affect it? But I really have no clue.
Old Dec 17, 2005 | 12:51 AM
Oh and I would not go by that oil change monitor. Starting in 2000 they raised the limit to 15K at optimal driving conditions. Another one of GM's stupid ideas, Kinda like the "lubed-for-life" chassis parts, "filled-for-life" Transmission and the 100,000 mile spark plug.
lol
Old Dec 17, 2005 | 06:16 AM
JimS's Avatar
Changing the oil is such an important thing that I can't figure out why you'd trust it to the pcm or why you' d cut back on the frequency of oil changes. It can't save much money... not enough to justify maybe hurting your engine. Maybe I'm misreading your post.
Old Dec 17, 2005 | 12:36 PM
kbracing96's Avatar
To answer your question, no. Flashing the pcm does not reset your oil change light. I was wandering this too, so I checked. Mine came on at about 5000 miles and I had made about 10-15 flashed to the pcm with EFIlive.
Old Dec 17, 2005 | 12:40 PM
kbracing96's Avatar
And to add to that, one of the flashes was a full reflash to a custom os.
Bluchevypick
Aug 18, 2015 09:11 AM
Suburbazine
Aug 9, 2015 01:17 AM
rojeho
Aug 8, 2015 07:20 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Suburban2500
Jul 14, 2015 02:10 AM
