Deleting Rear o2's with EFIlive - HOW TO?
Old Sep 5, 2008 | 06:39 PM
foxySS's Avatar
Default Deleting Rear o2's with EFIlive - HOW TO?
Hey guys, I found out the source of my misfire headaches. Bad Magnaflow cats.
Can someone tell me how to delete the rear o2's with EFI live?
I'm running open headers until I get this problem resolved.
Thanks
Old Sep 5, 2008 | 08:26 PM
viciousknid's Avatar
Where's the Beef?
Someone will correct me if i'm wrong but I think you go to your tune tool. Engine Calibration / Cat Converter / Parameters and disable B0701
Old Sep 5, 2008 | 08:50 PM
kbracing96's Avatar
In the engine diagnostics DTC's, set everything with O2s bank 1&2, sensor 2 to "not report". Should be about 8 things if I remember right. Also set P0420 and P0430 to "not report" also. Do the same thing in the DTC's MIL enabler too.
Old Sep 6, 2008 | 02:01 AM
foxySS's Avatar
It looks like everything was set correcty but I still get an emissions light. I will have to run the codes tomorrow and see what popped up. To loud for night time...
Old Sep 6, 2008 | 04:15 PM
foxySS's Avatar
Well, I thought the cats were the problem... But low and behold it's still misfiring like a bitch. It looks like Justin turned all the 02 codes off last time he worked on my tune. The first time I drove it after no cats it ran fine, second time and there-on it got a p0300 epa and a regular p0300.
This is the list of what I have done to troubleshoot thus far:
- Swapped Plugs NGK TR55's w/NGK tr6's
- Swapped Plug Wires and put back on stockers
- Swapped Coils around
- Did Compression test and Leakdown test
- Checked fuse box for bad grounds
- Put in new Walbro 255 fuel pump
- New Fuel filter
- Seafoam in fuel system and PCV
- Ripped Cats off
- Put turndowns on open headers so front O2's aren't picking up pure oxygen.
Things I have not done:
- Swapped rear 02's with front ones (maybe they were bad because of cats backing up.)
- Pulled injectors out to clean them
- Put stock plugs back in
Guys have any more ideas?
Old Sep 6, 2008 | 04:55 PM
brobradh77's Avatar
maybe a bad injector???
Old Sep 6, 2008 | 05:01 PM
kbracing96's Avatar
Are you getting a lot of misfiring that you actually feel, or does it just keep throwing the P0300 code?
Old Sep 6, 2008 | 05:07 PM
Where's the Beef?
Mine was missing real bad and it was because of a bad front o2.
Log a run and look on Dashboard B at your voltage on the o2 sensors (ho2s11 and HO2S21. if its moving up and down its working.
Here's when my bank 2 went out.
Log_0000
And when I fixed it.
Log_0006
File Type: efi
File Type: efi
charcold-bowtie's Avatar
check the plug wires, especially the top on the coils. Its so easy to not set them in all the way.
Old Sep 6, 2008 | 05:09 PM
Where's the Beef?
btw. when my o2 went out it didn't throw any codes. but it's worth checking.
