Daily Driver Tuning
Old Dec 2, 2011 | 09:12 AM
Lucille's Avatar
Default Daily Driver Tuning
Anybody have general guidelines about what I should be seeing on my gauges during normal everyday driving?
Timing & AFR at idle?
Timing & AFR at light throttle cruise +/- 1700 rpm?
Old Dec 2, 2011 | 09:47 AM
smokeshow's Avatar
Mod with training wheels
Light throttle cruise and idle should be 14.68 AFR. Idle timing depends on what sort of idle control it uses...gen 3 uses airflow idle trims, gen 4 uses adaptive idle timing. From what I've seen, gen 3 stuff has a little higher idle timing, stock is around 20°. And gen 4 is lower around 10. Doesn't take a lot of torque to idle. Cruising timing is in the 30-40° range. I push that as high as I can before MBT to get the most mileage.
Bluchevypick
Aug 18, 2015 09:11 AM
mrhino
Aug 7, 2015 10:01 AM
Cm_gmt800
Aug 3, 2015 09:13 PM
sauldgold
Jul 23, 2015 02:15 PM
lxcoupe
Jul 21, 2015 02:12 AM
