couple diagnostic code questions
Old Jun 3, 2007 | 11:24 AM
sdimess84's Avatar
Default couple diagnostic code questions
I just got done putting 03 5.3 in my s10. I have two check codes. Was going to try to get some input on them and how i might get rid of them.
Code: P0405, EGR sensor A cirvuit low
Code: P1860, TCC/PWM solenoid circuit
Any help will be greatly appreciated.
Old Jun 4, 2007 | 08:45 AM
sdimess84's Avatar
anyone.....
Old Jun 4, 2007 | 08:57 AM
dewmanshu's Avatar
Moderately Differentiated
a 2003 5.3. Stupid question...did you put egr on? I am assuming you have tuning software. Lots of questions to be had here, transmission? You have a custom harness for the trans. Speed sensor plug in correctly?
Old Jun 4, 2007 | 09:10 AM
Wilde Racing's Avatar
How do I change this text
Like dew said, 03+ engines DO NOT have EGR, but the older ones do, so If you are using your stock PCM, I'm not sure how. But the codes will need to be turned off. the trans code is for the lock-up soleniod, check the wirring to the soleniod, be sure to check pins in every connector, (i've seen pins not fully pushed in at the trans connector cause problems). If all else checks o.k replace the TCC soleniod, they cost around 20-40 buck.
Old Jun 4, 2007 | 10:10 AM
sdimess84's Avatar
well i was talking to the guy the programmed my computer, i think im TCC code because im using a older style 4l80e and it is wire/programmed for a newer model 4l80e. Could I swap the solenoid out for the newer model one?
Old Jun 4, 2007 | 10:58 PM
There really isn't too much different between the 4l80e's well I take that back the oil temp sensor changed. What year is the 4l80e that you have?
Old Jun 6, 2007 | 02:29 PM
sdimess84's Avatar
im not exactly sure what the year is. it looks like its from 97ish 98ish truck. i hoping it is just a small fix.
Old Jun 7, 2007 | 09:14 AM
were are the oil cooler lines? are they both next to each-other on the right front side. Or is one of them a little further back on the right side?
Old Jun 7, 2007 | 12:14 PM
sdimess84's Avatar
they are right next to each other. Just like all the other trannies
Old Jun 13, 2007 | 11:19 AM
sdimess84's Avatar
Well i got problems figured out. The egr code i turned off with my diablo tuner. And the TCC problem i found the wire that controls it and changed the pins, and the code went away. Now just to see if i get better gas mileage is the real test!
Noah Burns
Sep 7, 2015 05:50 PM
Jblake
Aug 17, 2015 12:59 PM
LaBlackIce
Aug 15, 2015 10:55 AM
rojeho
Aug 8, 2015 07:20 PM
USMCvet0311
Aug 1, 2015 07:45 AM
