Cluster swap, now battery light on???
Old Mar 1, 2014 | 09:15 AM
78TA's Avatar
Default Cluster swap, now battery light on???
Swapped clusters in my truck (05 silverado 5.3) to one of unknown year with trans temp gauge. Everything seems to work fine, except now dummy battery light constantly lit up when running. Anyone know why, and is there a remedy to this? I have unplugged and checked, no bent pins or anything and install old cluster and light goes out.
Old Mar 1, 2014 | 06:11 PM
Suburbazine's Avatar
Cluster must be programmed to match your VIN (basically, the truck's RPO codes must be set in the cluster). Any Tech II can do this.
Old Mar 1, 2014 | 09:07 PM
78TA's Avatar
That's the first I have heard they needed programmed other than to correct mileage.
Old Mar 2, 2014 | 04:05 PM
newcastle916's Avatar
pretty sure it has to do with alternator or the wiring, cluster you installed is from a 03 or 04
Old Mar 2, 2014 | 05:56 PM
99-02 only had to have mileage programmed. They were not communicating with the BCM for vehicle data, sensor feeds are input directly. 03-07 Classic communicate with the BCM which relays data to the cluster from each equipped option. Each option has it's own digital address, meaning if the cluster programming does not match this address map then one or more features will go stupid.
In very rare cases you can find 03-07 clusters from exactly identically equipped vehicles, in which case you don't have to get them reprogrammed.
Old Mar 3, 2014 | 03:36 PM
78TA's Avatar
Thanks for the info guys !!
Old Mar 3, 2014 | 03:42 PM
78TA's Avatar
Another question, can I mix parts between my old and this new one to get a working trans temp Guage in my old cluster? I was planning on rebuilding my old cluster with all new stepper motors. Is the circuit board for a non trans tem Guage and one with the same ?
Old Mar 3, 2014 | 10:01 PM
I think all you have to do for trans temp is add the stepper motor. I haven't done this though, so it may not work.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
hartinclay
Aug 3, 2015 07:03 PM
ou812sm
14
Jul 27, 2015 04:38 AM
ou812sm
Jul 23, 2015 02:11 PM
Ketis
Jul 23, 2015 12:37 PM
