anyone know how to test cluster without installing?
Old Dec 10, 2011 | 08:54 PM
mitchellmade's Avatar
MASS seller approved
Default anyone know how to test cluster without installing?
i have a couple 03-up clusters i want to list i know worked before pulled just dont have mileage on them. cant test it in my trck because i have a 2000 silverado thanks for any help
Old Dec 11, 2011 | 09:10 AM
TXSZ66AVLANCHE's Avatar
I made a harness that plugs into a cig lighter so I can check miles and test operation, hard to explain how to make it though.
Old Dec 11, 2011 | 01:13 PM
Fastcount03's Avatar
Anyone know where to find a pin out for the plug on the cluster??
Old Dec 11, 2011 | 06:01 PM
Suburbazine's Avatar
Do you have the necessary equipment to reprogram them to work in another vehicle? Any test you do will be a failure if the cluster doesn't recognize the new vehicle's VIN.
Old Dec 11, 2011 | 06:24 PM
Clusters aren't vin matched on the 03 up trucks you can plug and play. The only difference the VIN makes is for programming options like DIC control, curb view settings etc.
All you need to do is power the ign input which is pink and ground and it'll light up.
Old Dec 12, 2011 | 12:56 PM
Alpinestar's Avatar
Yea, but his truck is a 2000 so that might not work. Are you just wanting one that goes to 120mph? The '99-'02 Escalade clusters do and I think the 1500 HDs might also.
Old Dec 12, 2011 | 01:38 PM
thunder550's Avatar
High on diesel fumes
Sounds like he's just trying to verify that they work and the mileage on them so he can list them for sale.
Old Dec 12, 2011 | 03:07 PM
CalEditor@PCMCalibrators's Avatar
FormerVendor
Pin --- Wire Color --- Circuit No. --- Function
A4 ------ BRN --------- 41 -------- Ignition 3 Voltage
A5 ------ GRY -------- 1036 ------- Class 2 Serial Data
A6 ------ BLK -------- 1850 -------- Ground
A7 ------ GRY ---------- 8 --------- Illumination Supply Voltage
A8 ------ BLK/WHT ---- 451 -------- Ground
A9 ------ ORN --------- 340 ------- Battery Positive Voltage
A10 ----- PNK -------- 1020 ------- Ignition Positive Voltage
B1 ------ LT BLU ------- 14 -------- LH Turn Signal
B5 ------ PPL/WHT ---- 1382 ------- LED Dimming Signal
B6 ------ PNK ---------- 39 -------- Ignition Positive Voltage
B10 ---- DK BLU ------- 15 -------- RH Turn Signal
2002 - 2006
A6 ------ GRY --------- 1036 ------- IPC Class 2 Serial Data
A8 ------ DK BLU ------ 2115 ------- Right Turn Signal Lamps Supply Voltage
A11 ----- RED --------- 2353 ------- Instrument Panel Lamps Dimming Supply Voltage
A12 ----- BLK --------- 1050 ------- Ground
B1 ------ LT BLU ------ 2114 ------- Left Turn Signal Lamps Supply Voltage
B9 ------ PNK --------- 639 -------- Ignition 1 Voltage (w/o 8S8)
B11 ----- ORN -------- 2840 ------- Battery Positive Voltage (w/o 8S8)
B12 ----- BLK/WHT --- 1851 ------- Ground
Old Jan 14, 2012 | 08:50 PM
thanks for the info guys ... wish i could get the details on the cigarette lighter hook up or even with any 12 volt power supply still have those clusters but havent touched any of em yet
Zacholcomb
Aug 23, 2015 11:25 PM
brandon6.0
Aug 19, 2015 07:48 AM
08lambochevy
Aug 14, 2015 07:50 PM
hartinclay
Aug 3, 2015 07:03 PM
Matt C.
Aug 1, 2015 01:25 PM
