Am I out of Fuel Pump? Hit a Lean Area at 6500 RPM
Old Sep 18, 2019 | 07:24 PM
Tampa Tuning's Avatar
Former Vendor
Default Tuner in Tampa
Originally Posted by RedXray
Really don't know where to add fuel without making the tables rich below that spike. It's perfect 6100 and lower but at 6400 it starts to go lean (rev limiter is set at 6500). .
Look at your Hertz (HZ) on your MAF to tell you were to add fuel. Which on your screen print is 10822 HZ. If you want to be broad, your about 8 percent leaner than your target. Go a cell 10750 to 11000 Hz and add in 1.05 percent fuel to make it richer. If your in Speed Density, then you have to look at your VE table and make the corrections in that RPM area.
But then again I dont think you're running out of injector with 50 pounders, but I question if you have like "FAST" or another brand name 50 pound injectors that just drill the holes bigger and does not provide injectors data, there's several tables to fudge with no data and the tune is never great because your fudging rather than adding in proper data.
But honestly when I see incorrect data entered in a calibration, its usually the low end parking lot and cruising driving that the vehicle has a problem.
It a bit more expensive to get injectors that have data, but it makes life easier for the tuner and the vehicle.
rel3rd
36
Feb 15, 2011 07:03 PM
07 z71 silverado
Dec 17, 2008 10:20 AM
2ktransam
Apr 1, 2008 12:19 PM
vanillagorilla
20
Jun 17, 2005 07:27 AM
Chevmann99
Nov 19, 2004 07:05 AM
