In Tank High Capacity Pump
I started a thread on this the other day and got some info on inline units, I would really like an intank pump. Here is the story: I recently dumped the Procharger FMU and went w/ 43lb injectors, and tuned accordingly (see sig for all mods). Now I am losing fuel pressure in the last few hundred RPM before the shifts, (shifts are set at stock right now, but I plan to up them a few hundred RPM in the near future) pressure drops from 60 to 50-52, and there is a little noise from under the hood, (maybe some detonation, or injector noise from running out of fuel?) Anyway I am currently running the inline aux pump that came with the Procharger, but I have a feeling it is designed for high pressure not high volume, (verified it is running, and changed the inline filter already). I am sure I'm going lean and will just get worse if I up the shift points. I want an intank unit but can only find this one (part number 30-7032) is this the one I want? It's too late to call tonight. Anybody have any other sources they could point me to? I didn't have much luck using the search feature. Thanks
I'd suggest the Walbro 255 w/ some high flow fuel rails. I'm running this pump on my 427 w/ 42# bosch injectors. The pump is supposed to be good to about 650HP I believe. It's a universal pump that will require some modification to run. Don't be scared by that though, the modification is minimal. Good luck.
I think you're pump may be bad, or not working. I still have the inline that came with the procharger, and it's feeding my engine fine. I'm maxing my MAF (600 hp) at around 5600 rpm in the cool weather.
I had the same thing happen once, and thought the pump was working, but it was just picking up vibration from the intank pump. Turns out I had a bad ground.
Also, have you had it on a wideband yet with the new tune? It's possible that it's tuned so rich and dumping so much fuel that you're maxing out the pump when you don't need to be.
GXPJAY
Jan 27, 2016 11:45 AM
Ferocity02
Jul 17, 2015 07:05 PM
