ABS EBCM pains 2003 silverado ss
Old Dec 13, 2012 | 01:44 PM
buccnazty's Avatar
Registered User
Question ABS EBCM pains 2003 silverado ss
hi there new to the forum i like it alot.
my truck is a 2003 silverado ss 65000 miles
after storage for the last 18 months i took it to get gas and when i was driving it the abs light came up, and it sounded like a pump was stuck on. the break pedal goes pretty low and mush.. i took it home and sourced the noise to the abs controller on the drivers side frame rail or the EBCM electronic brake control module. the vacumm for the brakes stays on even with the key out so i took out the abs fuse and the noise ceased. before i spend 800$ on the new EBCM does anyone have any ideas what it could be. or if this is the best way to fix it.? has anyone sent there module out to be fixed, or reworked it themselves.? thanks alot also what are the dangers of running with abs unconnected!
Old Dec 22, 2012 | 01:12 PM
buccnazty's Avatar
Registered User
come on no answers no pms this is a huge pain for me i have looked down the whole truck and this is the only real problem
Old Dec 22, 2012 | 10:05 PM
MikeGyver's Avatar
You need to test the wheel sensors first.
Old Dec 23, 2012 | 08:15 AM
03sierraslt's Avatar
Mine did the same thing years ago and it was the ABS Controller or pump cant remember, it was covered under warranty.
Old Dec 23, 2012 | 09:24 AM
scooter k's Avatar
If the pump is running constantly then the EBCM needs replacement. Never sent one in to be repaired but have a friend that tried it and had good luck.
Old Dec 23, 2012 | 09:29 AM
skolman91's Avatar
Like mentioned you should check your sensors first or for any codes. But you can send it off and get it rebuilt for alot less from what ive read and works just as good, and you can still drive it without it or abs, the brakes will work fine you will just not have any abs aka lockup control like on ice or gravel etc..
Old Dec 23, 2012 | 10:51 AM
MikeGyver's Avatar
Originally Posted by buccnazty
... and it sounded like a pump was stuck on. ...
Originally Posted by scooter k
If the pump is running constantly ...
I guess I skipped over that part.
Old Dec 23, 2012 | 12:29 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Definately a bad EBCM with the symptoms listed in the OP.
Old Dec 23, 2012 | 01:45 PM
buccnazty's Avatar
Registered User
serious thanks to i am going to send mine out to a guy on ebay he has like 97% feedback ill let everyone know how it goes.
thanks alot for the tips. how do i check the wheel sensors.?
zblee
63
Jun 10, 2023 01:25 PM
D1SCSS
Jan 25, 2016 10:14 PM
pjb1972
Sep 17, 2015 02:06 PM
Ketis
Jul 23, 2015 12:37 PM
