8.1 Tuning with EFI Live
I am new to the forum and was directed here from the duramaxforum that I am on alot. A friend of mine has an 06 2500 with an 8.1L in it. Several years ago he had it tuned by a guy that has since retired. Overall he likes the tunes he has but at colder temperatures the truck does not start or idle well till it is warmed up. I have downloaded his tune and just started looking at things on it but since EFI Live is new to me I am not exactly sure where to begin. Under fuel/crank/start is where I am thinking I need to adjust to richen the mixture until the truck reaches a certain temperature after start. Can someone give me some pointers on where to begin. Any help would be appreciated.
Do you have a wideband? How long is it running before it starts running OK? When an engine starts it runs in open loop meaning that the fueling is controlled by the fuel map. Once the O2 sensors are heated the engine then runs on the air passing through the MAF. (This is everything I have understood, I might be wrong but am willing to help)
Do you know what the fuel trims are? Before I start tuning there are several things I do. Checking fuel pressure like you have is a good idea. I make sure the air filter is in good condition, and I clean the MAF. The MAF might look clean, but have a coating of oil on it especially if you are running a K&N filter. Are you able to post the tune so we can see it?
ARC
57
Feb 21, 2022 10:54 AM
Raggedz71
Jul 29, 2016 10:20 AM
kr1s
Aug 24, 2015 05:34 PM
GMCtrk
Jul 17, 2015 06:39 PM
