6.0 tune
Old Feb 6, 2010 | 09:31 PM
TransWS6Am's Avatar
Default 6.0 tune
anyone got a lq9 swap into a 2000 z71 tune i can take a look at. or something similar. thank you! hp tuners files please
Old Feb 6, 2010 | 09:36 PM
TransWS6Am's Avatar
doing a lq9 swap into a 2000 z71 tomorrow and tryin to figure out what exactly i need to swap over on the tune too get it right
Old Feb 6, 2010 | 10:17 PM
TransWS6Am's Avatar
damn no one?
Old Feb 6, 2010 | 11:38 PM
Atomic's Avatar
I have a gauge for that
You posted this on a saturday night and it has barely been an hour....be patient.
As far as the tune goes, if you are just doing a lq9 swap and keeping the 4l60e, just copy the engine parameters from a vmax truck tune to yours. You can find one in the hptuners tune repository.
Old Feb 6, 2010 | 11:41 PM
TransWS6Am's Avatar
ok so just swap all the 6.0 engine stuff over and im good? the problem im running into is the buttons in grey, that there is no info from the 6.0 tune to swap over to the 5.3 computer. is this ok?
Old Feb 6, 2010 | 11:43 PM
Atomic's Avatar
yep, all of the electronics are the same......although im not sure if the 2000 pcm is the same as the 03+ pcm which is when the lq9 first appeared.
.....but I think it is
Old Feb 7, 2010 | 01:47 AM
Wheatley's Avatar
Truck Sponsor
00 PCM service number ends in 4896
03 ends in 106 or 605
Old Feb 7, 2010 | 02:04 AM
GMCtrk's Avatar
you'll need to use an 01-02 6.0 tune with cable TB.
Old Feb 7, 2010 | 09:45 AM
TransWS6Am's Avatar
wasnt the 2004 ss a cable tb?
Old Feb 7, 2010 | 11:31 AM
1Bear's Avatar
All the SS files will be a ETC. GM went to the electronic throttle control across the board in '03, while earlier model trucks with traction control, a few of the higher end models like the Denali's, C3's and so on, even the 8.1L trucks also had ETC before '03.
Just use a file for a '99 or '00 2500 with a LQ4 to get yourself started.
