6.0 swap
Old Jul 21, 2012 | 11:34 AM
  #21
Team Paulie's Avatar
Registered User
Theres a service port for the hood hinges..
Just relocate the springs to them and the hood will almost go to 12oclock. very handy anytime you gotta work under the hood. lets alot more light in also!
What or were are they?
Old Jul 27, 2012 | 01:52 PM
  #22
southern_chevy's Avatar
see the picture below and the bolt on the left remove it and i believe you either can install it in the lower hole or just reinstall the bolt and let the hook part of the hood bracket sit on it. Only works with stock hoods the cowl on cowl hoods hit the windshield first. ask how i know
http://image.truckinweb.com/f/tech/e...inge_bolts.jpg
Old Jul 27, 2012 | 10:55 PM
  #23
brent1976's Avatar
11 Second Club
With the different starters, check the flywheel and make sure they are the same. Get new tcc bolt that aren't allen head, it makes getting them in/out a lot easier. Leave the tranny part of the tune stock, you're 60e and wallet will thank you.
I did it the way you are, I switched all sensors and accessories I didn't replace with everything from the 4.8L, because I knew they all worked and had replaced the alt. battery, and other stuff over the years, and put a new water pump, and starter just because when I did the swap. The hood thing works good too. Take out the bolt and move it to the empty bolt hole, mine flips a little past 90*, I do it all the time while I'm working on it. My buddies with 03/04 Cobras are jealous of it because no matter what we do to them they have to take off the hood.
Old Jul 27, 2012 | 10:56 PM
  #24
brent1976's Avatar
11 Second Club
Oh yea, I do a crank relearn when I do just about anything to the truck also.
Old Jul 30, 2012 | 12:33 AM
  #25
Registered User
bit of a update,got the whole underside done,all front drives are off and swung away,buddy finally made it over to help me pull the converter bolts,NOW the the only thing left is to pull the motor mounts.....which with full lengths and very limited ground clearance I cant make happen.....SO I'm gonna pull the four bolts that hold the actually mounts on the frame and pull it forward enough to lift it out,swap em back over to the 6.0.
coils are out and bolted to the new engine,got a new started today too,gonna take some pieces into work and clean em up,hopefully Tuesday it comes out and get the new one in. 50% done and I have been chipping away at it when I can or fell like it.
Old Jul 30, 2012 | 09:16 PM
  #26
brent1976's Avatar
11 Second Club
I took the mounts off of the frame too. It was to hard with LTs in the road. A long extension and an impact makes pretty quick work of them.
Old Jul 31, 2012 | 09:14 AM
  #27
Registered User
I"m hoping tonight I have the 4.8 out,did you pull the radiator or leave it in?
Old Jul 31, 2012 | 03:54 PM
  #28
brent1976's Avatar
11 Second Club
Leave it in, there's plenty of room in these things.
Old Aug 1, 2012 | 04:33 AM
  #29
TXSZ66AVLANCHE's Avatar
Longest engine swap ever....lol
Old Aug 1, 2012 | 09:30 AM
  #30
Registered User
You try working 55+ hours a week Mon-Sat,come home and take care of a house,a handicapped grandparent,a hobby that might turn in too a full time job,other peoples **** I'm working on,AND then my truck.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Jake75
Jul 22, 2015 09:20 PM
Cowboy17
Jul 9, 2015 06:18 PM
