4L80e swap, won't shift 1>2 WOT
Old Feb 26, 2013 | 08:38 AM
LS1FREEK's Avatar
13 Second Truck Club
Default 4L80e swap, won't shift 1>2 WOT
Ok first off it's an 04 Silverado 1500, I'm using EFILIVE with custom OS 2, and of course I did the 4L80e segment swap. We've done many other 4L80e swaps and never had this problem before. The only thing I did different is not wire in the front input speed sensor, but I did turn all the DTC processing enablers off for it and disabled all the slip test stuff too. Shouldn't this work? It drives around just fine at all part throttle driving and the 2>3 WOT works fine too???? Also this trans was taken from my '89 turbo LS swapped truck and worked fine in there....
Old Feb 26, 2013 | 09:22 AM
03sierraslt's Avatar
It needs the front input speed sensor hooked up, at least to the best of my knowledge. Someone else recently had this problem also.
Old Feb 26, 2013 | 09:30 AM
BigDaddy0381's Avatar
I had that problem. hook the VSS up. When I didn't have mine hooked up no matter what was changed in EFIlive nothing changed in the trans. hooked it up and all went to how it was tuned for. I have also broke an VSS wire and the shifts were really hard, but that was one wire hooked up and one broke. nether hooked up it wouldn't shift at all.
Old Feb 26, 2013 | 09:33 AM
LS1FREEK's Avatar
Kinda what I had figured... ok thanks guys!!
Old Feb 26, 2013 | 10:30 AM
03regcab sierra's Avatar
You already did the trans swap on Jeremiah's truck?
Old Feb 26, 2013 | 01:52 PM
LS1FREEK's Avatar
Yup! Got it done last night, other than the iss wiring
Old Feb 26, 2013 | 01:59 PM
Cool. I miss that truck. Should haul *** now!
Old Feb 26, 2013 | 02:03 PM
Jake99's Avatar
Gunna do a little work to the nitrous system yet and throw a nice hit to her and see how it does, converters only a 3500 now but setup to work well with the n20.
Old Mar 6, 2013 | 10:39 AM
LS1FREEK's Avatar
Installed the ISS and works perfect now!
1slwgto
Aug 16, 2015 06:40 PM
dantheman1540
Jul 24, 2015 01:50 AM
Ammadien
Jul 22, 2015 08:50 PM
lxcoupe
Jul 14, 2015 10:14 PM
zaathur151
Jul 6, 2015 10:57 PM
