4l80 swap
Old Sep 13, 2018 | 05:45 PM
joesmobile1's Avatar
Registered User
Default 4l80 swap
i'm looking for a diagram to wire a 4l80 using a 4l60 tune
Old Sep 13, 2018 | 06:25 PM
arthursc2's Avatar
Not possible, have to segment swap.
Welcome to the forum, we have a very nice search function that will answer almost any 4L80 swap question you'll have.
Old Sep 14, 2018 | 07:45 PM
darkirish63's Avatar
If you use a conversion harness from Nelson or PCM of NC, you don't need a segment swap.
Old Sep 14, 2018 | 10:08 PM
arthursc2's Avatar
Before I admit defeat or accept that as fact, I will have to research it. Shift algorithms are different so not sure how wiring gets around that.
Old Sep 15, 2018 | 05:07 AM
madmann26's Avatar
The Nelson and PCM of NC harnesses use relays. They’re tried and true but expensive.
I would prefer wiring in the front sensor and repin the harness with segment swap.
Old Sep 18, 2018 | 07:55 AM
zz454Chevelle67's Avatar
I am running a 4L80 on the 4L60 tune and got all the info here in one of the stickies, had to wire in a 5 pin relay for 2-3 gear solenoid. If that relay comes unplugged tranny will go into limp mode, really sucks, I found out this Sunday thought I killed another tranny, relay was gone but was an easy fix. Zip tie mod now LOL. I will look for the info and post a link. Use the search thats how I found it a few years ago.
Old Sep 18, 2018 | 08:47 AM
tgui's Avatar
A million times this. Its not very hard to do as well. Move some pins, add a speed sensor, tune. Done. 100% OEM function.
Old Sep 18, 2018 | 11:29 AM
1FastBrick's Avatar
Custm2500's Rude Friend
I believe this is what your looking for.
https://www.performancetrucks.net/fo...g-swap-413157/
Blwn99x
Nov 27, 2016 05:21 PM
CUR4VNM
Nov 21, 2016 08:59 PM
Cougaar55
Nov 4, 2016 06:01 PM
richincanada
Oct 14, 2016 12:07 AM
Yelo
Mar 2, 2003 07:38 PM
