2002 DBW PCM no good for 2 bar even with a COS
Old May 19, 2011 | 11:39 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Angry 2002 DBW PCM no good for 2 bar even with a COS
So I am trying to get a tune built for my latest project. I want to go 2 bar as I will be running 12psi or so. Well my 2002 Tahoe is a rare breed. It has the DBW 87mm TB and a 512kb red/blue connection PCM 122004141. There are only 2 or 3 Operating Systems (OS) that run this combo in a 2002 Chevy truck. None of these have a Custom Operating System (COS) associated with it using EFI Live.
I am left with 2 choices:
1.Swap to a drive by cable throttle body.
2.Swap to a 1mb 2003+ PCM, TAC, and maybe the pedal assy.
I am actually leaning towards option 2. My question is will my 2002 wiring harness hook up? Will I need to swap pins around or does Speartech or EFI Connection make a harness for such a thing?
I need anyone who has upgraded to post up. As the truck sits I can’t do anything even after I get the engine in except maybe scale the injectors to get it started and idle but no way to tune it for WOT.
I have been on the EFI Live forums, E-mailed Justin@BlackBear several times, and talked to a dyno shop in Dallas. No one has a work around for this.
Help
Old May 20, 2011 | 09:51 AM
TX Tahoe Z71's Avatar
Odd. My mom's 2002 Tahoe is a cable TB and my 2003 is a DBW. I guess you got one in the middle.
Old May 20, 2011 | 10:53 AM
bigboy576103's Avatar
Ya it sux *** i have one i have had laying around for awhile cuz i dreaded messing with it but due to my latest BRIGHT IDEA i have decided to modifie this harness to DBC and make it custom lengths to clean up my engine bay , instead of trashing my perfectly good previous harness, just incase i F*cked something up lol...
I cant find much info on these harneses its a pain..
Its not bad converting it to DBC just follow the instruction for the blue/green wiring diagram.(I HOPE) but im still trying to figure out the o2 sensor part.. should get to it tomorrow..
Old May 20, 2011 | 11:45 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
This might be a silly question, but does HPTuners have a 2-bar OS that would work with your current PCM/DBW setup? If they do, buying HPT would be alot cheaper and easier in the long run, in my opinion. Could be worth checking into.
Old May 20, 2011 | 12:53 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Yours has DBW because you have traction control.
Old May 20, 2011 | 01:27 PM
1Bear's Avatar
In his case that’s true, but there were a few others that were like equipped without traction control. Trucks such as my ’01 C³ came with ETC, but not traction control, as did the ’02 Sierra Denali’s. For the most part though, only vehicles with traction control came this way before 2003.
Old May 20, 2011 | 01:39 PM
kbracing96's Avatar
Chris, I think your best bet is to just convert it to DBC and re-pin the PCM for the TPS and IAT and then you can run COS5 and be done with it. Converting to the 1 meg PCM and keeping the DBW I think would be harder then the cable setup with more problems. I know Allen Nelson as converted a few 03+ DBW's to 02 DBC with repining them and switching to the 0411 PCM's. You might talk to him about it.
Other wise your only option is to tune it 1 bar with the Maf and then the last row of the VE once it maxes, which is possible, but not ideal. But it works for Stock48,
Old May 20, 2011 | 03:30 PM
Allen @ Nelsons is the guru u need to talk to he can tell u positives and negatives of going each route.
Old May 27, 2011 | 10:05 PM
1SlowHoe's Avatar
Spoke to Nelson Performance. I was told to contact Allen directly with my questions which I did via email.
I have been in contact with Wheatley as well. He said he has found a COS from HPT that will work with my OS. That's what the gurus at HPT told him anyway. I am sending my PCM to Wheatley to have the HPT COS loaded and my current calibration information put into the new HPT COS.
This still leaves me un-tuned for my new setup but a little closer to getting there. What I need now is a tuner who is willing to do a 2-bar map boosted tune via the mail or through email (using HPT now) to get me running...Wheatley said he doesn't do 2-bar except in person.
I am about to buy HPT so I can fool with this thing but I need to find a tuner first. Anybody have any suggestions?
creekrat
Aug 2, 2015 01:27 AM
chvy=power
Jul 27, 2015 10:06 AM
bsgiffor
Jul 19, 2015 11:14 AM
GMCtrk
Jul 17, 2015 06:39 PM
