P 174
Old May 27, 2011 | 09:21 AM
03 BLACKOUTSSS's Avatar
Default P 174
P 0174, my mistake...
"system too lean, bank 2"
truck is giving me this **** now, anyone ever had it? potential causes?
I had this code in combination with the MAF code, cant remember what that was, but cleaning the maf solved the problem, at least temporarily. now the 174 is back, but no maf code. any ideas?
Old May 27, 2011 | 10:06 AM
Robert91RS's Avatar
Its often the intake manifold gaskets leaking but there's a ton of potential causes.
Old May 27, 2011 | 11:29 AM
okay, any potential of a bad maf causing that code? I have a feeling that the maf is going bad.
Or how about an exhaust leak at the collector? Pretty sure I have one those going on.
Old May 27, 2011 | 12:36 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Bad MAF will make both banks go lean. Probably not your issue.
Exhaust leak, yes. Bad O2, yes. Clogged injector(s) and/or bad cat, yes.
Old May 28, 2011 | 09:28 AM
Okay, I am replacing header gaskets to eliminate a leak that may or may not be the cause. The gasket on the #2 bank, passenger side header looked good, replaced anyway, but may not solve the problem.
Here's another question, I drove around today, monitoring with my handheld scanner, looking at fuel trims and O2 readings, and everything looks good. Bank 2 is running the same trims (long and short) as bank one. O2s are doing good, switching quickly. If I am running lean, would I see that in the trims?
tweeder
Sep 18, 2015 11:02 PM
walledition
Sep 14, 2013 07:55 AM
600 horses
Jan 31, 2010 12:28 PM
MOTTRHED
Sep 4, 2008 11:28 PM
