145 amp alt question
Old Oct 26, 2011 | 10:21 PM
getchusum99's Avatar
Default 145 amp alt question
do you guys know what years the 145 amp alternator was put stock on the 1500 chevy/gmc trucks? i lookin for a 145 amp to put on my truck, to go with the electric fans. i was thinking they started coming on the 05- up when the efans started coming on them stock. also is it a direct bolt up to my 99 with my 105 amp alt?
Old Oct 26, 2011 | 10:33 PM
charcold-bowtie's Avatar
yeah 05 and up, or earlier suburbans. You need an earlier one for it to plug right it, try an 03 surburban and tell them you want a 145 amp. I had a thread on this as well, if u look through my started threads...
Old Oct 26, 2011 | 10:36 PM
jrmchevyman's Avatar
I know in 2004 they had 130-145 amp alts that came in some of the bigger vehicles, AVALANCHE, Yukon/tahoe etc.
I found you a 130 amp direct bolt on delco for $98.50 at dbelectrical.com.
Look at that site and you will find it. 130 is more than enough unless you have a very powerful subwoofer system.
http://www.dbelectrical.com/p-3977-c...6-05-8237.aspx
My dad has a 1998 show truck and I ordered him a new alt from that site and it works perfectly. The original he had went out as the truck just sits in the garage and never used.
If you are wanting a 140-145 give them a call I am sure they have one.
Old Oct 27, 2011 | 12:04 AM
07NNBSVMAX's Avatar
My 07 Vmax has the 145 amp.
Old Oct 27, 2011 | 08:36 AM
the 07 v max probably has a diff plug on it as well tho.^^ thats why he needs an earlier version
Old Oct 27, 2011 | 09:18 AM
07NNBSVMAX's Avatar
Ahh good call didn't think about it that far.. Sorry man
Old Oct 27, 2011 | 02:56 PM
Link
So try an 03 suburban 2500, looks like what I used. should bolt right up, although I think you need a longer belt as well.
Old Oct 27, 2011 | 04:01 PM
nonnieselman's Avatar
Yep, need a longer belt. The stock one is so close but no fit.
Old Oct 27, 2011 | 05:43 PM
I wondered, I know it listed a different P/N, but I didnt try the shorter one
Old Oct 27, 2011 | 05:56 PM
ForcedTQ's Avatar
The alternator type you're specifically looking for is a AD244, with a 4 Pin connection. I don't believe we have a vendor specifically for Alternators here, so take a look at this link as it explains the AD244 as a 105 replacement.
GM AD230 to AD244 Alternator upgrade
Hope this helps.
