145 amp alt question
Old Oct 27, 2011 | 07:20 PM
2000chevysilverado's Avatar
Belt needs to be 1 inch longer have put one on my 2000 I had
Old Oct 27, 2011 | 10:07 PM
sand man's Avatar
take the newer DR44 it comes @160 amps the DR44G/DR37 is the 145
Old Oct 28, 2011 | 04:43 PM
ForcedTQ's Avatar
Lightbulb
Take the 170 amp version of the AD244, it's identical to the DR44, but has a replaceable bridge rectifier that is not built-in to the rear case like the DR44.
Old Nov 7, 2011 | 09:05 PM
getchusum99's Avatar
will the ad244 be a direct bolt up to my truck ? thanks for all the input guys
Old Nov 7, 2011 | 09:13 PM
dmelvin's Avatar
I've got a 200A that uses the same chassis as the 145, you just need to get a belt for a '05 w/145 alternator is all.
Old Nov 14, 2011 | 10:56 PM
i found a new 145 amp dr44 ,but it has a different connector than mine
Old Feb 26, 2016 | 09:11 PM
nshchevy0219847's Avatar
Registered User
i what know if a 145 amp alternator will work on my 2002 Chevrolet Truck Silverado 1500 2WD 4.8L SFI 8cyl. because i have a high power audio system the amp is a lanzar vibe 442n 5000w amp the 12 are 2 pyle pl1290bl blue wave 1200 watts
Like This
Quote
MultiQuote
Edit
Old Feb 27, 2016 | 01:22 AM
Suburbazine's Avatar
Like This
Quote
MultiQuote
Edit
First off, welcome to the forums!
Second off, please don't revive old threads. Make a new thread for questions instead
Thirdly, the Vibe is a 2000w amp when bridged, and theoretically only- it's really only going to put out 1100w or so, especially if you're running those subs in series with parallel drivers.
Either way, 145A isn't going to keep the lights from dimming and power being sucked off the battery when you're thumping. The 145amp alt makes about 600w at idle, 1000w at 2000rpm and 1500w at 4000rpm.
All the OE style alternators will be coil-wound style fields (inefficient, cheap, easy to make). The high-end alternators use hairpin windings with heavy gauge wire (high efficiency, expensive, hard to make) and usually have custom cases. Think MechMan or QualityPowerAuto (I run a QPA Mega Amp 320, makes 2000w at idle LOL so I'm kind of partial to them).
Texas5.3_1251
Mar 5, 2016 08:10 PM
Forcefed81
Sep 8, 2015 10:02 PM
bisqikss
Sep 8, 2015 03:35 AM
2004gibbstruck
Sep 7, 2015 06:05 PM
iregret
Sep 7, 2015 01:20 PM
