1.3 amp draw?
Had a bad alternator that was overcharging. Tested to see what they key off draw was and showed 1.3 amps. Haven't rechecked it since putting the new one on, but will tomorrow. Whats the normal draw? Does anything stay powered up for a few minutes?
I will wait 5-10 minutes to let the modules power down, sometimes longer. Then proceed to pull fuses one at a time until I find the problem. Remember to rig the door ajar switch when you have to pull fuses from the interior fuse panel.
The multi function thing is clicking. I took it out and put it back in and now it clicks about every second with a 4 amp draw. The radio wiring has a 6 amp draw so i know for sure theres a short in it.
the radio, bose amps and bcm, door modules and hvac controller do not go to sleep until several hours after the vehicle has been parked even though the key is off. It's also not uncommon to see the amp draw jump up and down as modules wake up and check the databus for communications then go back to sleep and repeat this cycle for several hours.
thompson
Sep 30, 2015 09:48 AM
slowlsx
Aug 10, 2015 05:33 PM
