04 silverado E-fan conversion using 05 oem fans, rad, and wiring harness
Old 11-19-2015, 09:00 PM
Believe what you want.
Old 11-19-2015, 09:03 PM
Wolftrk99's Avatar
What is that supposed to mean, not knocking anyone just know my fans in my 99 work same way my 13 silverado my 08 yukon and my buddy's 06 do....
Old 11-20-2015, 09:27 AM
James Workman's Avatar
Thanks so just to clarify with the 02 ecm and proper configuration the fans will work with the a/c on and off switch and coolant temperature will also act as an input for their controll
Old 11-20-2015, 09:28 AM
Oh and just secure the other wire that was removed out of the way, when you say use the oem harness is the two pin aftermarket harness acceptable?
Old 01-11-2023, 08:56 PM
Registered User
bblack1976's Avatar
Default Efan with oem parts
Originally Posted by 1994Vmax
As stated above.... you don't only tap one of the PCM connectors.... you go to both. Blue wire in pin 33 on the green PCM connector and Green Wire in the Blue Connector on pin 42.
Then just activate the fans outputs via either EFILive or Hp and you are good to go. I have done an 03, an 04 and two 05's( all HD trucks) with the oem e fans and oem harnesses. It's easy peasy.
I’m wanting to go to the Efan setup using oem parts for my 04 Silverado..any advice you can send my way such as a parts list would be greatly appreciated.
Old 01-12-2023, 09:30 AM
RB04Av's Avatar
Look in the Technical Write-Ups forum on this site. Couple of articles there, have everything you need.
bblack1976 (01-12-2023)
Old 01-12-2023, 11:36 AM
Registered User
bblack1976's Avatar
Thank you
ls2rcsb
11-20-2017 10:56 AM
ryanroma
06-01-2014 05:40 PM
zachm89
08-16-2010 12:29 PM
SS_bnoon_SS
20
07-08-2007 05:29 PM
multmigs
06-29-2005 09:59 AM
Quick Reply: 04 silverado E-fan conversion using 05 oem fans, rad, and wiring harness
