04 silverado E-fan conversion using 05 oem fans, rad, and wiring harness
Old Nov 19, 2015 | 09:00 PM
Believe what you want.
Old Nov 19, 2015 | 09:03 PM
Wolftrk99's Avatar
What is that supposed to mean, not knocking anyone just know my fans in my 99 work same way my 13 silverado my 08 yukon and my buddy's 06 do....
Old Nov 20, 2015 | 09:27 AM
James Workman's Avatar
Thanks so just to clarify with the 02 ecm and proper configuration the fans will work with the a/c on and off switch and coolant temperature will also act as an input for their controll
Old Nov 20, 2015 | 09:28 AM
Oh and just secure the other wire that was removed out of the way, when you say use the oem harness is the two pin aftermarket harness acceptable?
Old Jan 11, 2023 | 08:56 PM
bblack1976's Avatar
Registered User
Default Efan with oem parts
Originally Posted by 1994Vmax
As stated above.... you don't only tap one of the PCM connectors.... you go to both. Blue wire in pin 33 on the green PCM connector and Green Wire in the Blue Connector on pin 42.
Then just activate the fans outputs via either EFILive or Hp and you are good to go. I have done an 03, an 04 and two 05's( all HD trucks) with the oem e fans and oem harnesses. It's easy peasy.
I’m wanting to go to the Efan setup using oem parts for my 04 Silverado..any advice you can send my way such as a parts list would be greatly appreciated.
Old Jan 12, 2023 | 09:30 AM
RB04Av's Avatar
5 Year Member
Look in the Technical Write-Ups forum on this site. Couple of articles there, have everything you need.
Old Jan 12, 2023 | 11:36 AM
bblack1976's Avatar
Registered User
Thank you
ls2rcsb
Nov 20, 2017 10:56 AM
ryanroma
Jun 1, 2014 05:40 PM
zachm89
Aug 16, 2010 12:29 PM
SS_bnoon_SS
20
Jul 8, 2007 05:29 PM
multmigs
Jun 29, 2005 09:59 AM
