'02 silvy
hptuners for some reason doesnt want to read the pcm on a friends 02 silvy. with everything connected it says that there is no power to the pcm or to make sure the key is in the run position. i tried it like 5 times and still wont let me do anything. any suggestions? the trucks an 02 4.3. after hptuners wouldnt let me hook up to his truck, i tried it on mine and it worked perfectly.
Well **** then. Simple things first. Have you posted on HPT forum yet? DO you have a license to download your friends file and save? (I know, it doesn't matter, you still wouldn't get the error) Is he 100000000% sure that pin 16 is HOT with 12 volts?
I mysteriously would get the same thing with my truck sometimes...rare, but sometimes. It has to be a crappy wire in my OBDII bundle. Hmmm...ignore the fuse comment and make sure that pin has 12 volts in it and doens't have a clump of mud stuck in there.
Have you tried just scanning?
it wont let me do anything. once i plug it into the diagnostic port, all the gauges go wack. the fuel reads 0, battery light, check engine light, and a few others start screwing up. like i said, it works perfect with my truck
nope, under the dash. The link I posted above has a front "picture" of the OBD II port under his dash. Make sure everybody on HPT knows your licensing status, the fuse isn't blown, and you haven't verified voltage on the obd pin yet.
***EDIT***
What mods has he done? Messed with electric wiring? Give the whole skinny.
***EDIT***
yeah. i just got this hptuner in like last week so i dont think its messed up just his truck haha. hes f'ed with the wiring a little. hes had a pa, underglow, and rear light bar installed. the underglow he just curled around the battery terminals that screw into the battery haha.
dantheman1540
Feb 24, 2016 09:56 PM
mitchellmade
Sep 27, 2015 08:25 PM
