Supercharged silverado ccsb nnbs circle d 4l80e driveshaft truetrac clean lo miles
Old Nov 8, 2012 | 06:20 PM
chris092183's Avatar
Default $24.5k Supercharged silverado ccsb nnbs circle d 4l80e driveshaft truetrac clean
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
here is the dent on the Driver's side fender.
[IMG][/IMG]
[IMG][/IMG]
OK SO I AM NOT SURE WHICH WAY I AM GOING TO SELL MY TRUCK. I will either part it out and sell it stock or sell it the way it is.
2007 CHEVROLET SILVERADO C1500 CREW CAB SHORT BED GREYSTONE METALLIC
5.3
Most stock components are still available if you would like.
MODIFICATIONS
VORTECH SUPERCHARGER TWIN SCREW VTS2300
2007-2011 5.3L Truck/SUV:
The complete supercharger system will boost your stock 5.3L truck/SUV to 452HP and 444 lb/ft torque with 8.5 PSI from the Lysholm 2300 supercharger at the factory redline. With the supercharger alone this is an increase of 137HP and 106 lb/ft torque over the GM factory ratings.
This kit is $6250 without the $1000 Vortech installation fee. Total cost is just under $8000 with tax.
INNOVATE WIDEBAND WITH LC-1 GAUGE AND O2 SENSOR
Color matched gauge Dual Pillar pod
Doug Thorley long tube ceramic coated headers.
TRUE 3" dual exhaust into x pipe with Dynomax race bullets. Tips exit before passenger side tire.
NELSON PERFORMANCE COMPUTER PROGRAMMING
SFI LS flex plate is 0.156" thick, 25% thicker than OE. It is SFI 29.1 certified to withstand 12,500 RPM. It also has a special coating to prevent any rust.
CIRCLE D TORQUE CONVERTER 4L80E 3000K STALL SPEED
Pro Performance Stage I Billet Multi Disk
Converter Diameter - 258mm - 10 1/4"
100 Square inches of Clutch Lining for WOT Lock-Up
Furnace Brazed
Hand TIG Welded
Torrington Bearings
Billet Front and Billet Piston
3 Element Bearing Design for Longer Clutch Life
Flanged Impeller Hub for Anti-Flex Durability
Hand Assembled to Exacting Tolerances
Paid over $1100
2007 4l80E
Completely rebuilt
New frictions, steels, bushings, thrust washers bearings, o-rings, seals etc.
Enlarged pump orifices to prevent seal blowout
Dual fed direct drum
Thicker intermediate snap ring
sonnax boost valve
rollered output and forward hub
All new bushings, seals, pistons 34 element sprag.
B&M Deep pan holds 3 extra quarts aluminum with fins
ENERGY SUSPENSION TRANSMISSION MOUNT
It's not a unit built from one of the tranny builders on here but i built it to handle around 600hp/tq. If you purchase it for 30k I will throw in an extra
4l80e with the same build.
TRUCOOL 40,000 TRANSMISSION COOLER
INLAND EMPIRE DRIVELINE SERVICES 5 INCH DIAMETER BY .125 INCH THICKNESS DRIVESHAFT. 1350 YOKES
INLAND EMPIRE DRIVELINE SERVICES 5 INCH ALUMINUM DRIVESHAFT.
1/8 INCH THICK. OVER TWICE THE THICKNESS OF THE STOCK DRIVE SHAFT. 1350 YOKES
Paid over $750
INLAND EMPIRE DRIVELINE SERVICES REAR BILLET 1350 PINION YOKE
Paid $150
DETROIT TRUETRAC WITH 4.10 GEARS
INTERSTATE BATTERY 1200CCA
EXTERIOR
SNUGTOP SNUGLID SL TONNEAU COVER
cost about $1100 BUCKS
BED MAT
Paid $80 bucks.
Color matched Chevy emblem
De badged
BELLTECH 2 INCH DROP SHACKLES
PAID ABOUT $65
GOODYEAR SR-A TIRES 255/75/17 have about 75% tread. I have one spare brand new as well in addition to the stock spare.
TOW PACKAGE
FLAWS
There are a very few scratches and dents here and there.
Scratch on passenger side bed about 3.5 inches long
Small dent on corner passenger side of cab the size of a ball bearing
Scratch on hood in the middle about 3inches long
Driver side front fender has a small dent by the light
Tonneau cover has small chip by the passenger side cab.
Other than that the truck is in excellent shape and has always had a thick coat of wax and has always been garaged
Truck was over $34 grand at Harbor Chevy. I bought it in late September of 2007. Truck was built by General Motors in the middle of 2007. I am the original owner.
Synthetic blend was used till about 30k miles. After that Full synthetic was used.
Currently the truck has about 500 rear wheel torque/ rear wheel horsepower. That can easily be brought up with a different sized supercharger pulley. Currently, the truck is running at 8.5 pounds of boost. You can get the pulleys at Vortech for $78 bucks plus tax.
Lojack
Remote start
Z85 suspension package
$24.5k
Old Nov 8, 2012 | 07:16 PM
mdwatts11's Avatar
Nice truck. Good luck with sale.
Old Nov 8, 2012 | 07:41 PM
amanuel's Avatar
hmmmmmm
Old Nov 10, 2012 | 04:01 PM
Thanks man I put a lot into it. It's just time to part ways and get a work truck.
Old Nov 14, 2012 | 03:53 PM
Posted better pics. This truck needs a new home.
How about $23,000 for everything but the supercharger and verter?
Old Nov 18, 2012 | 04:22 PM
not clean enough? Is it because I don't have da dubz or underbody light kit? I can put some racing pedals and a Type R seat belt cover on it. How about those air duct ornaments?
Old Nov 26, 2012 | 12:14 PM
27k is a damn good deal!
Old Nov 27, 2012 | 12:36 PM
rfugio68.'s Avatar
glws man, where did you do the 4l80 swap and how much? I'm looking for someone in the area to do mine.
Old Nov 30, 2012 | 07:25 PM
Thanks man. I got a few offers but nothing over 24 so far. A guy wanted to trade his 2007 classic dmax for it but didn't want to add cash so I said no. A few days ago I got a trade offer for a ls2 gto with a bw 480 turbo plus $1k. We'll see what happens.
As for the swap I did it myself except for tuning. I can help you out with the swap if you need be. I also have a 4l80 layin around. If you dont have an extra pcm, there is a member who lives in Orange county on here that can probably tune it for ya. I don't want to offer his services so if you are interested let me know and I will ask him. I don't know if Reynaldo will drive to Orange County but he might have extra PCM's for your truck.
PM me if you need to know more.
Old Dec 1, 2012 | 01:53 AM
rfugio68.'s Avatar
That Gto offer seems tempting haha. Yeah I talked to Reynaldo already, I'm just gathering some parts (cooler, flex plate, and verter) then having him do the swap early January.
