1984 c10 LS swapped!
Bought this truck about 6 months ago from a well known member on the forum. Got the truck just for $hits and giggles, drove it home, drive around the block maybe about 5 times. Ive only put about 200 miles on it since I got it. Here is the original listing....
https://www.performancetrucks.net/fo...d.php?t=468345
Now onto the details:
Its a 1984 c10 with a 64,000 mile 02 5.3. motor is stock and in perfect shape.
It has full functioning accessories. a/c, power steering, power locks and power windows.
New interstate battery. New rotors with Napa adaptive one pads
The fuel system has a sumped tank mounted under the rear of the bed with a hinged door, has a MSD inline pump and it a return style system.
Exhaust is 2.5" Y'd together into a single 3" into a 3" two chamber flow with a turn down.
It has a built th400 with a circle D 3800 stall and a trans brake. The trans was built by a local shop and was guaranteed to hold up to 1000hp. it alone was $1800
Trans fluid cooler
Trans fluid changed and refilled with Amsoil
condensor fan added, to help with keeping cool in traffic.
driveshaft made by Kevins machine.
The rear end is a 12 bolt with 3:73's.
The wheels are centerline polished aluminum. not sure of the model of them.
The interior is in good shape. has a nice seat (redone) and currently has a dash cap but i have a really good shape factory dash pad for it.
Has a cd player and new 6x9's for the cab corners and 2 JBL 10's and an american pro amp.
The body is in decent shape. no rust anywhere except under the battery. a $45 inner fender liner will fix that. and if need be i will put new inner fender liners in it before i sell it. The roll pan needs a little work in the seam. and the upper cab corners need a little work but not bad at all.
I have a NOS 75 dry shot for the truck also.
The intior pic is old and is dirty. i have since cleaned up. the under hood pic was shortly after i got it running and have since did alot of wire hiding and under hood cleaning.
asking $5500. o.b.o
***$4900 if it gets sold by the end of July!!!***
Trans fluid cooler
asking $5500. o.b.o
Like I said, I bought the truck from him and drove it about 150 miles home with not a single prob. The guy has even got in touch with me a few times afterwards to see how she was doing! Totally stand up guy.
Ill PM you his info, I already told him I am trying to sell it so he will tell you all about it. I am really not the car guy, I just had an itch for a toy and scratched it....
