1984 c10 ls swapped.
1984 c10 ls swapped. New improvement's & pictures.
Now onto the details:
Its a 1984 c10 with a 64,000 mile 02 5.3. motor is stock and in perfect shape. I also have an 05 5.3 i just aquired that i was going to build up that can go with the truck.
It has full functioning accessories. a/c, power steering, power locks and power windows.
New interstate battery. New rotors with Napa adaptive one pads
The fuel system has a sumped tank mounted under the rear of the bed with a hinged door, has a MSD inline pump and it a return style system.
Exhaust is 2.5" Y'd together into a single 3" into a 3" two chamber flow with a turn down.
It has a built th400 with a circle D 3800 stall and a trans brake. The trans was built by a local shop and was guaranteed to hold up to 1000hp. it alone was $1800
Trans fluid cooler
Trans fluid changed and refilled with Amsoil
condensor fan added, to help with keeping cool in traffic.
driveshaft made by Kevins machine.
The rear end is a 12 bolt with 3:73's.
The wheels are centerline polished aluminum. not sure of the model of them.
The interior is in good shape. has a nice seat (redone) and currently has a dash cap but i have a really good shape factory dash pad for it.
Has a cd player and new 6x9's for the cab corners and 2 JBL 10's and an american pro amp.
The body is in decent shape. no rust anywhere except under the battery. a $45 inner fender liner will fix that. and if need be i will put new inner fender liners in it before i sell it. The roll pan needs a little work in the seam. and the upper cab corners need a little work but not bad at all.
I have a NOS 75 dry shot for the truck also. its wired up and ready to go but needs a line to run to the bottle and a bottle bracket to mount the bottle up to be functional.
The intior pic is old and is dirty. i have since cleaned up. the under hood pic was shortly after i got it running and have since did alot of wire hiding and under hood cleaning.
asking $5500. o.b.o and if i get my asking price i will deliver withing a reasonable distance. and by my standards reasonable distance is within 4 hours of me.
Trans fluid cooler
Thanks. It seeMs like everyone that has asked me about it has ran into the same thing. no one local seems to have any interest.
