00 Reg cab stepside 5.3 t56 $6500
Old Aug 26, 2012 | 11:24 PM
Turbo383SS's Avatar
Default 00 Reg cab stepside 5.3 t56 $6500
2000 victory red silverado with dark grey interior. Truck started life as a 6cyl automatic work truck fleet side. Ive owend the truck for 1.5 years. All mods were done by me and have less than 10k miles. Conservative 87 octane tune with hp tuners. 163k on body.
96k 5.3l with 216/224 cam, lunati springs, new oil pump, timing chain and -10 port in oil pan. new fuel pressure regulator. Large rails.
Stock manifolds, non catted y pipe and Flowtech phantom catback with stainless tip
F body electric fans
2001 T56. was told fresh rebuild by a place in OKC but was not done by me and didnt recieve a receipt when purchased. Shifts smooth. Has stock Hurst shifter with aluminum 2" ball. Ram HD clutch but installed with organic disk. original disc was too harsh on takeoff for a daily driver.
all new clucth pedal, master cylinder and slave from gmparts direct.
Stock 10 bolt with 3.42 gears and open carrier. Have a set of 4.10 gears included in the sale.
lowered 4/6 with 2" beltech spindles and 2" springs in front. 6 inch DJM flip kit with c notch in rear. Nitro drop shock on all 4 corners. all new ball joints and front hub bearings installed as well. djm flip allows adjustable pinion angle. currently set at -2.5 degrees.
all new brake system 5k ago including New front & rear rotors, new front & rear pads, e brake shoes and painted calipers.
Joe gibbs 20" wheels with 275/40/20 Kumho tires with 75% tread
Aftermarket tahoe grille
5% tint
Interior consist of power window conversion with gm regulators and spal switches. Bose door panels, 05 tan 10 way power seats, center console, and lower dash pieces. clarion cd player.
steel roll pan with hidden hitch behind tag
Step side bed was bought from a member on here. Painted victory red but doesnt match perfectly. most dont notice but is off by a shade or two. (red is very hard to match perfectly.) has raptor liner but is chipped in spots. Roll pan was installed later and paint matches cab perfectly.
$6500
Old Aug 26, 2012 | 11:29 PM
Turbo383SS's Avatar
Truck shows well but does have normal rock chips on hood and rocker panels. hood has few hail dings. Planned to replace with HD hood. shift boot is a new camaro boot but doesnt fit quite right. had to stretch to get to fit and is not perfect. no power locks only power windows. ICE COLD AC. It is going tomorrow to get a few door dings removed then to the detailer later this week to be detailed and buffed. call with any questions
918 899 8350
Old Aug 26, 2012 | 11:37 PM
Turbo383SS's Avatar
Have high mount turbo hotside that I built for the truck. 1/2 flange log manifold with crossover to drivers manifold. V band connections and flex tube. 2 1/2 mandrel bends 16ga. 1/2 t4 flange at turbo. 38mm tial style wastegate and 60# siemens injectors( all new ) will include at asking price otherwise $400.
Old Aug 26, 2012 | 11:40 PM
01RCSBSilvy's Avatar
i have a 5.3, would that turbo kit be everything that i need to run it. please let me know im interested in buying
Old Aug 26, 2012 | 11:46 PM
Turbo383SS's Avatar
no the kit is only the hotside. you will still need turbo, downpipe, intake tubing and intercooler if using one. this is basically the hard part to fabricate.
Old Aug 27, 2012 | 01:56 AM
mcalestermatt's Avatar
Would you be interested in trade for a 98 h/c/I z28 camaro?
Old Aug 27, 2012 | 03:42 AM
Mangled03gmc's Avatar
Baltimore Whore
Pics of the hot pipes.
Old Aug 27, 2012 | 09:40 AM
Turbo383SS's Avatar
I'll take pics and post them this evening
Old Aug 27, 2012 | 06:02 PM
Turbo383SS's Avatar
All dings are now removed including the hail on the hood.
Old Aug 27, 2012 | 08:56 PM
Bowtie502's Avatar
love the truck. glws
