Fire Pit Design
Old Jan 4, 2013 | 08:42 PM
OLD BULL's Avatar
Default Fire Pit Design
I'm having a pool built right now and we are going to have a natural gas fire pit built as well. The builder does not supply the insert pan or the burner. After doing a little surfing I'm learning that this will be quiet pricy for the size that we want. I have the equipment and the skills to build it myself, but just not sure about the burner details (holes/jet size and spacing). Any help is appreciated.
Old Jan 5, 2013 | 08:45 AM
Chevy_King1500's Avatar
are you just using the natural gas to start the fire??
Old Jan 5, 2013 | 09:34 AM
RibeiroBJJ's Avatar
Praise The Lowered
The colored broken glass looks cool, I know we set the 5/8" s/s tubing 1" below the surface of the glass (whick was 2" deep) and the rest was sand
Old Jan 5, 2013 | 11:35 AM
tiffo60's Avatar
I just added Propane pipe burners to my firebox on my smoker. I used one inch pipe with slits cut in it. Pointed the slits down so the fire would roll up from underneath. I used and wire welding gun tip to control the propane into the pipe. Works pretty good and with some trial and error I about have it right. Ill attach a pic that I used for reference when I started mine. But mind you this was set up for propane. I dont know how natural gas would burn in relation.
Attached Thumbnails Fire Pit Design-640x361px-ll-09900821_burner.035high2.jpeg
Old Jan 5, 2013 | 12:41 PM
OLD BULL's Avatar
It will be purely a gas fire pit, with glass or lava rock base.
Old Jan 5, 2013 | 01:40 PM
slowswb's Avatar
here check this out these are glass burner can use outside with gas logs or glass
Real Fyre Large Custom Burner System [OCBE-44] - $487.05 : Fire Magic Gas & Charcoal Grills, Real Fyre Gas Logs & Outdoor Kitchens
Old Jan 5, 2013 | 01:51 PM
lowered907's Avatar
Be sure to post pictures.
Old Jan 5, 2013 | 03:02 PM
o gotcha, ours just has a gas burner to start wood then you shut it off once the fire gets rollin.. it's very handy
Old Jan 7, 2013 | 07:15 PM
OLD BULL's Avatar
I will. I've got a game plan and started today. I'm making the insert out out 1/8" stainless steel with 2x2 stainless angle around the perimeter. This is essentially just a tray to hold the burner, lava rocks and logs.
00loudchevy
Dec 3, 2015 05:54 PM
legerwn
56
Nov 15, 2015 10:21 PM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
Velocity1
Oct 2, 2015 08:01 AM
Velocity1
Sep 22, 2015 01:32 PM
