TrailBlazer SS Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Trick to removing front intermediate axle shaft?
Old Dec 21, 2012 | 03:27 PM
DrX's Avatar
DrX
Default Trick to removing front intermediate axle shaft?
Have to replace the front diff on my wife's TB after it ripped itself apart. I'm yanking on the intermediate shaft but it doesn't seem to want to let go and come out through the oil pan. Seems to me that I'm already using more effort than would be possible with the GM tool. How much effort is normally required?
Old Dec 22, 2012 | 11:46 AM
DrX's Avatar
DrX
I was able to disengage it by punching it out from the diff end.
Old Dec 22, 2012 | 01:12 PM
scooter k's Avatar
I always snap a vise grip on the splines, pry against it and the pan, and pry it out!
Old Dec 22, 2012 | 01:47 PM
DrX's Avatar
DrX
Yeah I found prying worked better for the outer axles too.
What a PIA having to take half the truck apart just to get this out!
Old Dec 22, 2012 | 03:58 PM
scooter k's Avatar
I've had a ton of these apart and I've never seen that! What happen to this one? Wow!!
Old Dec 22, 2012 | 07:09 PM
DrX's Avatar
DrX
From what she described something was binding when she went to start up from a light and bang! Not sure if they were checking the fluid level at the place she takes it for lube service.
Old Dec 23, 2012 | 02:07 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Wow spun the bearing too... I would think if it was a low oil issue you see problems with the other bearings. I have a feeling you were just unlucky and got a unit with a bad case or bearing.
Is there any pitting on the spider gears in the center section???
Old Dec 23, 2012 | 05:35 PM
DrX's Avatar
DrX
Haven't had a chance to look at it that closely. Here's a couple of zoomed images from the photos I took previously. The case is full of rollers from this bearing.
Old Dec 25, 2012 | 10:34 AM
1FastBrick's Avatar
Hard to say for sure, but I don't think it was an oil or lack there of issue. I would lean more towards a bad bearing or a case flaw issue.
Although Lack of oil is always a possibility.
IMO if it was lack of oil you would see more wear on the parts in there.
It could be the crush sleeve didn't hold causing the pinion to walk,
It could be an issue with the case that led to part failure.
It's also possible the bearings weren't manufactured properly, I.e. the heat treating or surface grinding.
IMO, The fact that the bearing closest to the ring gear spun the race and has the most damage tells me something else was going on there. Even it it was low on oil, it should still be getting splash lube from the ring gear. I would expect the front bearing, near the yoke, to spin first from a lack of lubrication. I know that rear one would get tore up if the pinion was moving back and forth. That's obviously why she felt the binding effect when trying to take off from a start.
It's to late now obviously, but I always try to learn something from part failures.
Old May 21, 2019 | 05:53 PM
Fred Daniels's Avatar
Registered User
Default Scooter
hi I have an 03 tb and I'm having a hard time getting it out if like to hear from ya about it...716 553 5945
Choda
Jan 22, 2026 02:03 PM
chopperloco
Jul 10, 2016 10:45 PM
AUTOT3K
Aug 16, 2015 06:21 PM
SloSVO
Aug 11, 2015 07:33 PM
