Guys with cranked TB's
Just wondering how long you guys have been running your truck with the bars cranked and if you have had any issues with breaking anything in the front suspension. I have my bolts cranked all the way and the ride is definately rougher and I can deal with that no problem, but with cranked bars putting more stress on the front suspension are you guys noticing an increase in wearing of anything or negatives to the front end. I was thinking of maybe taking them down about an 1" but really like the lift up front. One of my buddy's told me that going off road on rough terrain I could break a front shock b/c of the over extension of the shock with the TB's cranked. So I was thinking of getting longer shocks anything else I should be worried about? I just had to replace a wheel bearing on the front left and with my wife starting to drive the truck more often I really dont want a wheel or something to fall off b/c of me tampering with the truck. Any help guys, thanks.
check out your CV angles too. If your angles are too harsh and you go off roading you you'll be blowing your CV joints. I'd pull the bolts down at least a few turns. Also, make sure you jack up the front to take the load off the TBs before you start cranking.
I have had the TB's maxed out on my Blazer for 4 years and I am on my third set of axles up front in 115k miles. No big deal though, I am VERY rough on it and the axles are lifetime warranty, so I just pull the bad one and get a new one free.
my tb's were cranked all the way with my 9-11 lift for 3 years and no problems. i just recently added a 3" body lift and turned down the bars slightly just to get more articulation out of the front. that is something to consider in the future if you dont want to come out of the pocket for a full suspension lift
I have been thinking about turning mine up since I rub on the frame on my 1990 chevy but I am running 38's with no lift and am worried that I will break something. I already have a bit of angle on mine since the front end is so light.
