Guys with cranked TB's
Import Moderator
ford keys are just torsion keys from an F150, they have a different index then the keys on our chevy keys. dont do the ford keys, not good for cvs... just crank the torsion bars up a lil and trim your front bumper, they should fit
Tin Foil Hat Wearin' Fool
Import Moderator
There are plenty of people getting away with running ford keys with no problems the main thing is to get longer shocks and everything will be fine. Main thing is when you are offroad and one a-arm is full extended dont do a sharp turn and gas it, you will break a CV if you wheel smart you will be just fine. Im going to run ford keys and gk bars up front so I can clear 35s and I have a set of rancho rs900x 4" lift front shocks so I dont have any problems. Many guys on GMFS running that setup(with 33s though) with no problems.
Piss Pumps for Sale
Location: Moncton, New Brunswick, Canada, The True North Strong and Free!
1 Post
im just saying from experience, i currently have the ford keys on my blue rcsb 4x4 and ive had problems wit my 4wd, so its not like im just makin **** up
Import Moderator
Originally Posted by Chevy Cowboy
You still got the RCSB 4x4? I thought you sold it? How much do you have the Ford Keys Cranked on it?
id say you can probably get about 1" outta bottoming your bolts down with stock keys... with the ford keys i put them on and its atleast 1-1/2" and i still got a ton of threads left... you GOTTA replace the shocks if your gonna do it, cause while your crankin that bolt, if you dont replace em, it will pull the top bushing right through the shock mount. but in all honesty, i wouldnt recommend doing it, im sure ppl have and im sure it runs fine, but my blue truck WAS fine before i did it, and now that its still done the 4wds Fd up
Piss Pumps for Sale
1 Post
yeah, thats too bad, I havent decided if I wanna lift my truck cause is so exspensive and the ford keys sounded like a good alternative but I dont wanna screw something up
P.S. BUY IT BACK, I loved that truck
Import Moderator
like i said it may or may not, but from my experience i wouldnt take any chances wit them again. Skyjacker actually makes a 3" lift thats like $1100 for gm 1/2 tons 99-06 now to, not just the 88-98s. and wats nice about it is i dont think you even have to drop hte front diff
http://skyjacker.com/products-search...tnumber=C9461K
