33x12.5's without a lift?
I have a 2002 Z71 Tahoe and would like to run some 33x12.5's...specifically the 325/50 20 Baja ATZ from Mickey Thompson. Could I crank the stock t-bars level and clear these tires? Or would a 1-2" spacer in the rear and some ford keys be needed. I don't have the bucks for a full lift yet but I still want some bigger tires.
Thanks
Thanks
I have 275/55 R20's on there right now which would be a 32x11 if they made such a beast. I had to trim a little off the front of the inner fender liner but other than that they fit.
Thanks for the help.
I have 305x65 or 75 R16 GY MTR on my 2003 GMC Z71 and they did not rubb without a lift. I just lifted my truck 3" in the front with no ford keys of anything all I did after looking under the truck is bought two new bolt which are m12 1.75x85 which are 1 inch longer then the factory. Cranked my torsion bars up all the way untill the key hitting the top of my cross member bar. That alone gave me 3 inches now I'm just waiting for the 2 in add-a- leaf to get in. I also had to weld a plate under each rubber stoper in the front because with the lift there ended up being 1-1/2 between the stopper and the a-arm which left the ride to bouncey for my likings.
