TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
would you weld it?
Old Apr 20, 2012 | 05:33 PM
kode-x-kustoms's Avatar
Default would you weld it?
Hey guys,
I'm trying to get the shock relocation done on my truck, I have the brackets and have the template for the upper mounts. Problem is my welder, a Clarke 130, is not big enough to weld the 3/16 for the uppers and the lowers is about the same thickness but obviously its getting welded to the rear end housing, how ever thick that is.
Should I hold out and wait till I can get my hands on a borrowed welder that will for sure be big enough to weld it, or could my 130 be enough if everything is double pass?
Thanks
Kody
Old Apr 20, 2012 | 06:04 PM
Cknox121's Avatar
You could try, turn the wire speed down and heat up. Go slow and let it melt both parts. But that's just MO. Some one migh advise different
Old Apr 20, 2012 | 06:18 PM
I tried a test pass on the bench laying flat in the vise the weld lays flat but I still don't think its hot enough.
Old Apr 20, 2012 | 06:41 PM
TXSZ66AVLANCHE's Avatar
Where you located?
Old Apr 20, 2012 | 07:08 PM
ltr450ryder's Avatar
Heat up slow side speed and do some manipulations to ur welding partner and u should be ok I have a Lincoln 135 at home and I've welded 3/8 plate just took a long time and I'm a welder in general. Good luck with it
Old Apr 20, 2012 | 10:01 PM
I'm located in Tampa Florida.
I don't think I would have a problem with it, but I don't feel like having to re do it.
Old Apr 20, 2012 | 10:10 PM
make sure its clean and take ur time and u shouldn't have to
Old Apr 20, 2012 | 10:51 PM
Yeah I plan to pull the axle to weld the lower tabs, and I might re-design the upper mounts to get more "welded" area.
Old Apr 20, 2012 | 11:09 PM
If ur worried about of make gussets for them
Old Apr 21, 2012 | 02:41 PM
1FastBrick's Avatar
Custm2500's Rude Friend
pre-heating will help too!!!
