would you weld it?
Hey guys,
I'm trying to get the shock relocation done on my truck, I have the brackets and have the template for the upper mounts. Problem is my welder, a Clarke 130, is not big enough to weld the 3/16 for the uppers and the lowers is about the same thickness but obviously its getting welded to the rear end housing, how ever thick that is.
Should I hold out and wait till I can get my hands on a borrowed welder that will for sure be big enough to weld it, or could my 130 be enough if everything is double pass?
Thanks
Kody
Thanks
Kody
Heat up slow side speed and do some manipulations to ur welding partner and u should be ok I have a Lincoln 135 at home and I've welded 3/8 plate just took a long time and I'm a welder in general. Good luck with it
