Fs: Custom fuel cell
up for grabs is the custom fuel cell that everyone and their dog keeps asking me about
centers the weight of your fuel between the frame rails and puts it all behind the axle where you can actually use it for better traction. 17 gallon capacity and fits nicely under the bed. 450+ship and i get a good deal on shipping. i will also include the fuel lines and fittings that will be needed to make it all work. some slight modifications need to be made to install this system. you must cut spare tire crossmember out and give a little extra clearance on the bottom side of the bed to clear the fuel pump. nothing major but i didnt want anything thinking it was a direct bolt in setup. it was built specifically for a silverado. the OEM fuel pump/bucket will also drop in. bars on the pump need to be shortened to fit the shorter depth, and it is easy to trim them down.
