wiring harness for 2004 silverado
Old May 10, 2008 | 09:54 AM
LEballistic's Avatar
Default wiring harness for 2004 silverado
which stereo harness do i use? gonna put in an avic-d3
i see two different ones for sale for GM 1988-02 (his one has like 4 plugs)
and one for Chevy/Pontiac/Toyota 2000-2003 (this is only one plug)
anyone have a picture of the one needed
Old May 10, 2008 | 02:11 PM
spitfire2332's Avatar
well theres a few diff ways to do it, and then it depends on if you have bose and/or onstar.
Metra makes the vehicle specific harness, roughly looking at $100. Will keep your chimes, RAP, and onstar/bose if you have it.
Other wise there is another harness you can buy, I cant recall the part number. You will lose chimes, onstar, cannot use it if you have bose and you'll have to run your own accessory wire.
you can always give metra a call, cant think of their hours right now. Just tell them what you have, they'll probabaly give you a GMOS-01 or similar part #, thats the $100 one, if you dont care to lose all that **** just ask them for the other harness that doesnt retain all that stuff. 800-253-8324
Old May 10, 2008 | 02:12 PM
BassBaller5's Avatar
are you trying to retain bose? onstar? RAP? door chimes?
Old May 10, 2008 | 03:07 PM
i dont have bose. just want the chimes. but can do without for now. would just like the deck to be working
Old May 10, 2008 | 03:29 PM
if you want the chimes you might as well just buy the right harness the first time, cheaper in the long run. Any car audio shop, as well as circuit city or best buy if you dont have a local shop should have the harness. If they carry metra its going to be part # GMOS-01. You'll also need an antenna adaptor and dash kit if you dont already have those/didnt know.
Old May 10, 2008 | 03:53 PM
i need teh dash kit too? thought i didn't because the avic-d3 was a double din? so i need the GMOS-01, antennae adaptor, and dash kit. got the part numbers for the other two?
Old May 11, 2008 | 12:16 PM
yeah you still need a dash kit, theres a little area around the headunit that would be bare, and you really wouldnt have anything to mount to.
antenna adaptor is # 40GM10
the dash kit metra calls for is # 99-2003, it doesnt seem right though. I thought they just made a small trim plate for when using a double-din. I'd just go to a stereo shop. If they use metra you can save them some time by having those other part numbers, but you'll just have to tell them what your truck is, whats going in it.
Old May 11, 2008 | 05:42 PM
this it?
METRA - 95-3302 - 2004 - 2006 Chevrolet Turbo custom stereo installation kit.
http://www.audiooutfitter.com/95-330...a/p658455.html
Model: 95-3302
FEATURES :
Designed Specifically for the Installation of Double-DIN Radios or Two Single-DIN Radios
High-Grade ABS plastic - Contoured, Textured & Painted to Compliment Factory Dash
Comprehensive Instruction Manual
All Necessary Hardware to Install an Aftermarket Radio
ARC
57
Feb 21, 2022 10:54 AM
D1SCSS
Jan 25, 2016 10:14 PM
vortecyota
Jul 23, 2015 08:26 PM
85SS/85GN
Jul 22, 2015 12:48 PM
Nimoryan
Jul 5, 2015 03:50 PM
