Speaker Upgrade Help
Old Oct 2, 2012 | 09:45 PM
Ferocity02's Avatar
Default Speaker Upgrade Help
I'm in the process of upgrading my stereo system. The previous owner did some upgrades himself but I didn't know what exactly. I got around to removing the door panels and found MB Quart CD146 4x6's in the rear and Polk EX2560 6.5's, tweeters, and crossovers in the front doors. One of the 4x6's was dead, so I was going to replace it. What about the Polk speakers? They are working fine, just curious if there is something better.
My head unit is a Kenwood BT952 with 22W RMS, 50W peak per channel. I will not be adding an amp for the speakers. I'm looking for speakers that this unit will have no issue supporting. Will the Polk speakers be too much for this unit?
This should hopefully be my last thread about car audio
Thanks!
Old Oct 2, 2012 | 10:41 PM
BlackGMC's Avatar
Resident Retard
I love my focal componets... They are about 2 years old and sound as good as the day i installed them and they get flat out abused everyday... They are pricey but well worth it.
Old Oct 2, 2012 | 10:50 PM
WICK3DxGATA's Avatar
^^^ focal is amazing i wish i could get me some.
first off what is your budget.
another option i would suggest would be the rockford t1s.
and if these are going in your extended cab i would replace the 4x6s in the back with 6.5s. its what i did you barely have to trim out any and they fit perfectly.
Old Oct 2, 2012 | 11:36 PM
Ferocity02's Avatar
I would prefer to not trim at all. I looked at the 4x6 T1's, and they are 45W RMS when my head unit is only rated for 22W RMS. Is this an issue? Do I have to find a speaker that is below 22W? I will not be blasting them very often, but don't want to fry things when I do. These are also a bit pricey for me.
Will the Polk mids and tweeters in the front cause damage? They are rated 2-70W RMS. Thanks
Old Oct 2, 2012 | 11:52 PM
Ferocity02's Avatar
I've been looking at these: (Sort Best Rated) 4" x 6" Speakers | Car Speakers | Car Audio | Car Audio, Video & GPS at Sonic Electronix
I'd like to keep it under $70 each.
Old Oct 3, 2012 | 12:15 AM
Originally Posted by Ferocity02
im not one hundred percent positive if the RMS is to low if it will affect them. but yeah the t1s are quite expensive.
and out of the ones on the link you sent i would have to go with either the pioneer or the jl audio. im a fan of both of them. MTX ive heard good things about but my experience with them just isnt the best. my friend has those infinitys that are 69.95 and they dont sound to bad.
Old Oct 3, 2012 | 06:10 AM
jbancs's Avatar
Those polk speakers will be fine running off a head unit, but I would suggest running some small amplifier just to get better performance out of them. Look at alpines KTP-445U, it can easily fit behind your dash and will reuse your current stereos wiring to boost power output to 45watts rms per speaker.
That being said, I would look into the pol DXi460 speakers. They sound pretty good, off either a head unit or amp, but be aware that if you're going to run more power to them, any 4x6 speaker needs to be crossed over properly to avoid overrunning the mechanical limits of the speaker by trying to make it play too low, I'd recommend setting a high pass filter to somewhere around 100hz.
Old Oct 4, 2012 | 12:50 AM
Ferocity02's Avatar
Thanks for the help. I went ahead and got the Polk DXi460's. Good specs, high sensitivity, and now all of my speakers will be Polk.
I'm going to keep the front component speakers in unless someone suggests otherwise. The Kenwood unit seems to handle them okay. I don't like terribly loud music so hopefully there won't be an issue.
Alco
Oct 4, 2015 06:58 AM
Chevy305
Sep 28, 2015 09:21 PM
Raiderjim
Sep 28, 2015 10:37 AM
sTNT971
Sep 26, 2015 06:27 AM
97_ek
Sep 23, 2015 09:16 PM
