Power Wire through Firewall, where?
Old Aug 17, 2006 | 07:20 AM
Question Power Wire through Firewall, where?
I'm going to add a single 10" sub to my 2006 Silverado Crew Cab.
Where is the best place to run a 8 GA power wire through the firewall?
Any pics?
Old Aug 17, 2006 | 07:32 AM
onebadrubi's Avatar
on my 00 their was a graumet,sp?, behingd the ebrack pedal but up a little. under the hood it is right behind the fuse box and that support brace. between the brake booster and fender.
Old Aug 17, 2006 | 08:27 AM
Nick™'s Avatar
I went through the big grommet with the main wiring harness. directly above the fuse panel on the driver side floor/firewall or under the brake booster. Just take a pcoket knife and slit it on both sides and run a coat hanger through it - from there you can tape your wire to the coat hanger and pull it back through. I've done this on 4 trucks now.
Old Aug 17, 2006 | 08:57 AM
F8L Z71's Avatar
Maybe not the best way to do it but I also used the stock grommet like described above. It works
Old Aug 17, 2006 | 09:13 AM
thunder550's Avatar
High on diesel fumes
Yep me too, I ran a 1/0 gauge wire through mine. I also drilled two more holes close by to run the rest of my various wires though. Filled up both holes already
Old Aug 17, 2006 | 08:55 PM
9GMC9's Avatar
I put 4 gauge through the driverside door, here are some pics.
Then under the driverside panels.
Old Aug 18, 2006 | 12:28 AM
laynlow77's Avatar
ghetto ^^^^ run it through the spot for the clutch pedal that you probably dont have used. under the driver side dash. easy to find
Old Aug 18, 2006 | 12:25 PM
budhayes3's Avatar
PT's Slowest Truck
I've run a bunch of different wires through the stock grommet...it's a bit of a bear to snake em through, but it's doable. Gonna see if I can find some pics...
Old Aug 18, 2006 | 12:29 PM
budhayes3's Avatar
PT's Slowest Truck
Here ya go...
Old Aug 18, 2006 | 10:41 PM
laynlow77's Avatar
yeah thats the one....looks a little bit better IMO
